Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Strange post processing resuls for parallel computation of Onera M6 tutorial
Old   June 21, 2013, 06:29
Post Strange post processing resuls for parallel computation of Onera M6 tutorial
Akash Chaudhari
Akash C is on a distinguished road
Sorry for posting this query in optimization section, but there wasn't any better location with installation and announcements being the only other sections for SU2.
There seems to be some issue with using parallel computation for ONERAM6 tutorial. I used 2 parallel processes for this case. The flow.vtk file shows strange structure around the wing when viewed in paraview. This did not happen in case of 2D flows. Could there be some problem while merging the solutions of the two domains?
If anyone has faced the same problem or has answer to this problem, please help.
Akash C is offline   Reply With Quote
Old   June 21, 2013, 07:20
Cean
shirazbj is on a distinguished road
Better use plt file.
vtk file is not supported now.
shirazbj is offline   Reply With Quote
Old   June 28, 2013, 18:47
Thomas D. Economon
economon is on a distinguished road
Indeed, we are moving toward supporting Tecplot files and CGNS as our open file format. Many improvements have been made to the Tecplot ASCII writer already, and the next several developer releases should contain more upgrades in the binary formats (such as faster/cleaner file merging in parallel, removal of partition boundaries in the files, etc.).
Thanks for working with the code,
Tom
economon is offline   Reply With Quote
Old   June 29, 2013, 02:30
Post
Akash Chaudhari
So in the future versions would there be no support for paraview?
Old   June 29, 2013, 03:00
Cean
I just linked cgns lib and the flow.cgns can be viewed by paraview. I prefer use VisIt instead.
Old   July 2, 2013, 02:16
Akash Chaudhari
So did you make modifications in the source code? Because as far as I know SU2 only gives output in .plt and .vtk formats, also csv for the history file.
Old   July 2, 2013, 05:35
Cean
Only need to ChangE in cfg file to specify output in cgns format.
Old   August 19, 2013, 12:37
Francisco Palacios
fpalacios is on a distinguished road
The developers' version of SU2 includes a brand new paraview output. If you have a while, please check out the new code https://github.com/su2code
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   August 30, 2013, 05:30
Akash Chaudhari
Hi Francisco,
I compiled the latest version from github. But I do not get .vtk files in the output even when I specify PARAVIEW as OUTPUT_FORMAT.
Do I need to link any libraries to the code in order to do this?
Thanks,
Akash
Old   August 30, 2013, 06:05
Akash Chaudhari
Figured it out. Just had to run
./SU2_SOL config_file.cfg
after renaming the restart_flow.dat to solution_flow.dat.
Hi Francisco,
Thanks,
Akash
Question about post processing qtian OpenFOAM Post-Processing 0 July 24, 2007 12:44
UDF for post processing mvee FLUENT 0 May 23, 2007 12:13
Tecplot for CFX post processing pantangi goud CFX 2 August 24, 2005 16:42
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 20:51
