January 16, 2013, 20:58 |
JST Artificial Dissipation
I was looking through the JST artificial dissipation code implemented in the function CCentJST_Flow::SetResidual() in numerics_convective.cpp. I have not been able to find references for some of the scaling factors used in the JST artificial dissipation code. Can you explain the meaning of "StretchingFactor", "sc2" and "sc4"? Alternatively, can you point out the paper that this is from? Do they have something to do with the aspect ratio of the elements? Code:
Local_Lambda_i = (fabs(ProjVelocity_i)+SoundSpeed_i*Area); Local_Lambda_j = (fabs(ProjVelocity_j)+SoundSpeed_j*Area); MeanLambda = 0.5*(Local_Lambda_i+Local_Lambda_j); Phi_i = pow(Lambda_i/(4.0*MeanLambda+EPS), Param_p); Phi_j = pow(Lambda_j/(4.0*MeanLambda+EPS), Param_p); StretchingFactor = 4.0*Phi_i*Phi_j/(Phi_i+Phi_j+EPS); sc2 = 3.0*(double(Neighbor_i)+double(Neighbor_j))/(double(Neighbor_i)*double(Neighbor_j)); sc4 = sc2*sc2/4.0; Epsilon_2 = Param_Kappa_2*0.5*(Sensor_i+Sensor_j)*sc2; Epsilon_4 = max(0.0, Param_Kappa_4-Epsilon_2)*sc4; /*--- Compute viscous part of the residual ---*/ for (iVar = 0; iVar < nVar; iVar++) val_resvisc[iVar] = (Epsilon_2*Diff_U[iVar] - Epsilon_4*Diff_Lapl[iVar])*StretchingFactor*MeanLambda; Code:
Epsilon_2 = Param_Kappa_2*max(Sensor_i, Sensor_j); Thanks, KW |
January 17, 2013, 03:29 |
I would also like to know more about this scheme.
This may be a basic question since I am not very familiar with JST scheme. The JST scheme in SU2 also has first order dissipation, e.g., the config files have Code:
% 1st, 2nd and 4th order artificial dissipation coefficients AD_COEFF_FLOW= ( 0.15, 0.5, 0.02 ) |
January 18, 2013, 21:32 |
#3 | |
Francisco Palacios
Cheers, Francisco |
January 18, 2013, 21:44 |
#4 | |
Francisco Palacios
Cheers, Francisco |
January 19, 2016, 23:20 |
Kan
Rep Power: 12 |
I am also curious with the following code: /*--- Computes differences btw. Laplacians and conservative variables, with a correction for the enthalpy ---*/ Diff_U[nVar-1] = Density_i*Enthalpy_i-Density_j*Enthalpy_j; I guess this is used for the artificial diffusion term of energy conservation equation, but why do you change from total energy to enthalpy? Thank you, Kan |
artificial dissipation, jst |
Artificial dissipation for NS equations, flow in a pipe | RameshK | Main CFD Forum | 8 | November 13, 2011 10:29 |
Artificial Dissipation | TheBoyce | Main CFD Forum | 2 | March 23, 2011 15:27 |
Require a paper of artificial dissipation by Eriks | leaf | Main CFD Forum | 1 | June 19, 2006 23:34 |
Looking for a paper about artificial dissipation! | leaf | Main CFD Forum | 0 | May 18, 2006 16:52 |
Artificial Dissipation | Fereidoun-e-Jam | Main CFD Forum | 0 | April 6, 2005 07:33 |
