-   SU2 (http://www.cfd-online.com/Forums/su2/)
-   -   Axisymmetric flows (http://www.cfd-online.com/Forums/su2/113125-axisymmetric-flows.html)
praveen February 13, 2013 00:44
Axisymmetric flows
Hello
Is it possible to solve axisymmetric flows with SU2 in which there is also a swirl component of velocity ? So velocity has three components to be non-zero but there is no theta dependance of any of the variables.
fpalacios February 15, 2013 20:47
Originally Posted by praveen (Post 407534)
Hello
The axisymmetric with the swirl component is not implemented, but you can always run a 3D case with periodic bc.
Cheers,
Francisco
praveen February 16, 2013 01:42
So I would make a 3-d mesh like a wedge and apply periodic bc on the two angular faces. Is it enough have one layer of cells in the angular direction ?
fpalacios March 24, 2013 00:13
The current implementation 2.0.2 requires a hub, and at least 3 cells in the azimuthal direction.
Best,
Francisco
