Home > Forums > Software User Forums > SU2
Inviscid Onera
Old   March 17, 2013, 15:05
Default Inviscid Onera
cody
codygo is on a distinguished road
Generic Warning: Generic Warning: In /home/cody/Downloads/paraview/ParaView-3.98.1-source/VTK/IO/Legacy/vtkDataReader.cxx, line 1388
Error reading ascii data. Possible mismatch of datasize with declaration.
I computed the results using both MPI and SU2_CFD, using PARAVIEW output. The non-MPI version does not seem to provide Mach_Number variable in the surface_flow.vtk. The MPI version does output Mach_Number, but it does not appear correct.
The lambda pattern is visible, correct, and identical for Pressure_Coefficients in both MPI and non-MPI versions of surface_flow.vtk.
What could cause these errors? I have tried using Paraview 3.14 (Ubuntu default) and Paraview 3.98-1 compiled manually with no effect.
codygo is offline   Reply With Quote
Old   March 19, 2013, 19:55
cody
I have since computed the turbulent onera case in parallel using the default mesh and received the same errors in Paraview when opening surface_flow.vtk
I have computed tutorials 1-5 and 7 without issue, so I opened the flow.vtk (volume mesh) in Paraview for inviscid and turbulent Onera cases, the former computed in serial and parallel, to find that all the information was available and qualitatively correct (M_max 1.53 M_min 0.109), even though Mach_Number is missing from the surface_flow.vtk output. I'm assuming the larger range of Mach number is due to the range of Mach number throughout the volume as opposed to the surface values shown in the tutorial.
I didn't find any part of the configuration file that allows one to select/omit output variables to the Tecplot or Paraview files. Barring that I'm assuming this is a bug in the Paraview output?
Old   March 20, 2013, 12:36
Abhii is on a distinguished road
Hi
I have received same error for turbulent Onera using fine mesh available in test cases, but only when I run multigrid.... if multigrid is off the Paraview output is good.
Abhii is offline   Reply With Quote
Old   March 21, 2013, 21:34
Francisco Palacios
fpalacios is on a distinguished road
Thanks a lot for your interest in SU2,
The new version of SU2 (2.0.2) counts with a new I/O based on Tecplot (binary and ascii), and CGNS (that can be used by paraview users). As far I know VisIt counts also with a Tecplot reader (https://wci.llnl.gov/codes/visit/).
Anyway, using the current structure of the code it is very easy to create a paraview output format from scratch. If you are interested, my recommendation is to use output_WriteTecplotASCII.cpp as baseline and write something similar for paraview. Once you finish it, if you are interested, we can add the code to the official release (with the appropriate credits for the authors).
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   March 21, 2013, 21:51
Cean
shirazbj is on a distinguished road
VisIt is beter than ParaView in reading Tecplot binary format.
shirazbj is offline   Reply With Quote
Inviscid Flow cfd seeker Main CFD Forum 0 October 8, 2012 00:53
Inviscid Euler flow Ryan Sidin CFX 1 May 18, 2007 22:36
Inviscid flow solver luca_g OpenFOAM Running, Solving & CFD 0 December 21, 2006 12:55
inviscid Sylvain FLUENT 6 October 30, 2005 13:58
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
