Home > Forums > Software User Forums > SU2
Output flow file for v2.0.2
Old   March 24, 2013, 19:14
Default Output flow file for v2.0.2
Kevin Holst
kevinholst is on a distinguished road
It appears that the flow.* output file for this development release is not working properly. The code produces a flow.dat file that looks like a TECPLOT file even if you specify PARAVIEW, and I can't seem to get it to read in Paraview. Is there a work around for this?
Thanks,
Kevin
kevinholst is offline   Reply With Quote
Old   March 24, 2013, 20:03
Cean
shirazbj is on a distinguished road
i think the paraview vtk part is commented out.
you'd better use VisIt 2.6 to read the tecplot file flow.dat.
shirazbj is offline   Reply With Quote
Old   March 26, 2013, 14:58
Thomas D. Economon
economon is on a distinguished road
Hi guys,
We are in the middle of an overhaul on the solution output formats. We are no longer supporting the Paraview format directly, rather we will be supporting Tecplot ASCII (.dat), Tecplot binary (.plt), and CGNS (.cgns, an open format that can be used with most visualization packages, including Paraview).
Look for more updates as we go. Cheers,
Tom
economon is offline   Reply With Quote
[swak4Foam] Error installing swak4Foam Hisham OpenFOAM Community Contributions 182 February 8, 2024 10:36
parallel code samiam1000 SU2 3 March 25, 2013 04:55
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
