Home > Forums > Software User Forums > SU2
SU2 Ship Hydrodynamics?
Old   April 9, 2013, 15:15
Default SU2 Ship Hydrodynamics?
kilroy's Avatar
kilroy is on a distinguished road
Is it possible to run a ship hydrodynamics problem with SU2?
kilroy is offline   Reply With Quote
Old   April 11, 2013, 13:09
aniketaranake is on a distinguished road
Hi Kilroy,
This type of simulation can be performed by solving the level set equations. The most recent version (v2.0.2) contains many improvements on this. See the section titled "FREE SURFACE NUMERICAL METHOD DEFINITION" in the file trunk/config_template.cfg to see configuration options.
For a reference you may want to look at the following article:
Palacios, F., Jameson, A., Alonso, J. J., "Shape Sensitivity of Free-Surface Interfaces Using a Level Set Methodology," 30th AIAA Applied Aerodynamics Conference, AIAA Paper 2012-3341, New Orleans, LA, June 2012.
Regards,
Aniket
aniketaranake is offline   Reply With Quote
Old   April 12, 2013, 09:01
kilroy's Avatar
Hello Aniketaranake,
Thank you for your response. I have looked into the file that you have mentioned.
But my concern is a little bit different. According to the documentation provided by SU2 developers, SU2 is mainly a compressible code and its incompressible solver uses artificial compressibility formulation developed by Chorin to solve incompressible problems. However, Chorin's formulation is only valid for steady-state conditions. Because of that, although SU2 should be capable of simulating calm water resistance problems, I think it can not be used for seakeeping simulations which is highly transient.
Are there any new developments in the new version to improve that too?
Thanks,
Kilroy
Old   April 13, 2013, 14:06
Francisco Palacios
fpalacios is on a distinguished road
Thanks,
Kilroy
Hi Kilroy,
Despite our main research application is optimal shape design (steady state regime), we are using a dual-time strategy (second order in time) to simulate unsteady two-phase problems. In other words, we fully converge an artificial compressibility problem at each physical time step.
On the other hand, thanks to the steady state convergence acceleration techniques of SU2, the artificial compressibility is efficient even solving unsteady problems.
We will update a tutorial to our web page in the near future.
Best,
Francisco
fpalacios is offline   Reply With Quote
OpenFOAM Ship Hydrodynamics kilroy OpenFOAM 1 February 9, 2017 04:05
Welcome to the Stanford University Unstructured (SU2) forum! economon SU2 0 January 7, 2013 02:48
Best Software for Ship Hydrodynamics Soheyl Main CFD Forum 0 July 13, 2012 19:49
Ship hull hydrodynamics Costa Main CFD Forum 2 May 19, 2012 21:41
turbulence model for ship hydrodynamics ettax Siemens 0 January 20, 2009 05:02
