Home > Forums > Software User Forums > SU2
Benchmarks for SU2
Old   March 27, 2013, 06:38
Default Benchmarks for SU2
Goran Stipcich
karboidrat is on a distinguished road
Hi there,
This is a kind request to the developers.
After the installation of SU2 (both serial or parallel version) on my machine, I would like to make sure that everything went fine by verifying that I get exactly the same results as in the provided test cases.
Would it be possible to make available for download some Solution files of the test cases? For instance the files "solution_flow" and "surface_flow" (both in Paraview and Tecplot format), convergence history, etc. Maybe just for some of the standard test cases provided (Onera6 wing, Naca0012 air foil, ... )
It would be very useful along with the compiler's options used for installing, and both for the Serial and Parallel versions.
Thank you for your time and work. And please accept my apologies if the benchmarks are already available somewhere and I just was not able to find them.
Cheers,
Goran
karboidrat is offline   Reply With Quote
Old   April 11, 2013, 13:44
aniketaranake is on a distinguished road
Hi Goran,
Internally, we use continual regression testing to make sure that our commits do not break previously verified test cases. The python scripts for this purpose are available for you to run yourself. Make sure you have the directory su2/TestCases and run the command:
$ python TestCases/serial_regression.py
or, for parallel,
$ python TestCases/parallel_regression.py
This will execute a number of test cases and check them against previously verified results. I encourage you to run these scripts overnight, as they do take a while to complete.
Cheers,
Aniket
aniketaranake is offline   Reply With Quote
Old   April 18, 2013, 11:18
Goran Stipcich
Dear Aniket,
Thank you very much for your time!
I will try out the phyton scripts.
Kind regards
benchmark, post-installation, su2
any benchmarks results before buying computer eternityboy Hardware 0 July 5, 2012 01:24
Benchmarks andy_ Main CFD Forum 0 June 18, 2009 07:31
CFX benchmarks on the new Woodcrest (Xeon 51xx)? Joe CFX 2 June 29, 2006 08:47
CFD Benchmarks for workstations Charles Crosby Main CFD Forum 2 June 10, 2003 06:41
Drag prediction benchmarks Althea Main CFD Forum 12 October 18, 1999 12:57
