-   SU2 (http://www.cfd-online.com/Forums/su2/)
-   -   CFL ramp option (http://www.cfd-online.com/Forums/su2/115406-cfl-ramp-option.html)
curky March 30, 2013 05:54
CFL ramp option
I would like to dectrease CFL number during iterations. In the example configuration file there is an option CFL_RAMP:
% CFL ramp (factor, number of iterations, CFL limit)
CFL_RAMP= ( 1.0, 50, 2.0 )
I have tried this but it looks like CFL limit is only upper boundary.
When I set:
CFL_NUMBER= 100.0
CFL_RAMP= ( 0.8, 100, 0.1 )
program don't use ramp option and all iterations use CFL=100.
When I set:
CFL_NUMBER= 100.0
CFL_RAMP= ( 0.8, 100, 100 )
program use ramp option but in every 100 steps it change CFL. In a result I almost get convergence but CFL is so small that I can't reach it.
Is there any solution to set lower boundary of CFL number in ramp option?
Amrita Lonkar April 11, 2013 13:25
Thanks for your question.
I understand that you are trying to decrease the CFL as the number of iterations increases. This option is not available in SU2, but it's a very easy to implement.
I suggest you go to the file config_structure.cpp in the folder trunk/Common/src
Then, go to the method, UpdateCFL of class CConfig.
The very first set of lines are:
if ((val_iter % int(CFLRamp[1]) == 0 ) && (val_iter != 0)) {
change = false;
for (iCFL = 0; iCFL <= nMultiLevel; iCFL++) {
coeff = pow(MG_CFLRedCoeff, double(iCFL));
if (Adjoint) coeff = coeff * Adj_CFLRedCoeff;
if (CFL[iCFL]*CFLRamp[0] < CFLRamp[2]*coeff) {
CFL[iCFL] = CFL[iCFL]*CFLRamp[0];
change = true;
For your case in which you want to decrease the CFL, these lines of code should be replaced by,
change = false;
if (CFL[iCFL]*CFLRamp[0] > CFLRamp[2]*coeff) {
change = true;
Hope this helps,
Amrita
