Home > Forums > Software User Forums > SU2
Marker interface
Old   April 14, 2013, 00:48
Default Marker interface
richyricardo_2000 is on a distinguished road
I have been trying to run a simulation using SU^2 to analyze a rocket nozzle flow in a supersonic exhaust diffuser. I have been encountering some issues with the problem that I believe is due to information not being communicated across the nozzle exit and the diffuser inlet. For this situation, I believe I should be using MARKER_INTERFACE to define the interface between the rocket nozzle exit and the diffuser inlet. The reason I say this is that even with the rocket nozzle and diffuser running with the design conditions, the flow goes from supersonic at the nozzle exit to instantly subsonic at the diffuser inlet. I have verified by increasing and decreasing the total pressure and diffuser exit pressure, respectively. Is this true? If so could someone provide me an example on how to specify MARKER INTERFACES in SU^2's configuration file?
richyricardo_2000 is offline   Reply With Quote
Old   April 14, 2013, 00:57
Default More information
Here is some more information about my file. I am using Euler as my solver, and the setup is 2D, axissymmetric. For the initial solution, I do not use a turbulence model. I hold my CFL number constant at 1.0.
I have attached a screenshot of my geometry. The rocket nozzle is a Mach 4.4, contoured nozzle. The diffuser geometry is a second-throat exhaust diffuser with a subsonic diffuser at the end. The total pressure and temperature at the nozzle inlet is 500 psia and 5600 deg R, respectively. The ratio of specific heats (gamma) is 1.22. The diffuser exit pressure is ~ 14.174 psia.
My objective of this simulation is to determine the diffuser's starting pressure ratio (total pressure / diffuser exit pressure). According to my calculations, the diffuser should be started for a pressure ratio greater than 21. I have ran this case with another CFD solver (ISAAC) to help solve my problem, and I was able to run successfully with ISAAC. Increasing the number of iterations did not help with this problem; it actually made it blowup (NaN).
Old   April 14, 2013, 18:10
Default Mesh?
dtucker's Avatar
David Tucker
dtucker is on a distinguished road
That thumbnail shows an outline of your nozzle, but doesn't show your mesh domain at all...would you post an image of your mesh?
dtucker is offline   Reply With Quote
Old   April 15, 2013, 23:20
Default Another approach
After talking to Dr Power, I do not believe the marker interfaces are the issue. I will try re-running with a lower test cell pressure for marker inflow, and also try using the SA turbulent model.
Old   April 16, 2013, 21:27
Default It's working!!!
Finally, I got it working. I think the issue may be in my nozzle design. The total pressure had to be increased to 5000 psia, 10x's more than the calculated value. For amusement, enjoy the video:
http://www.youtube.com/watch?v=AXwGVXD7qEQ
Old   April 18, 2013, 13:17
Francisco Palacios
fpalacios is on a distinguished road
Great! Anyway, in this kind of problem the right boundary conditions are MARKER_INLET and MARKER_OUTLET, and keep in mind that the initial values are computed using MACH_NUMBER, AoA, and FREESTREAM_PRESSURE.
Best,
Francisco
fpalacios is offline   Reply With Quote
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
