April 24, 2013, 07:16 |
Problem at restart
Aldo Bonfiglioli
Rep Power: 13 |
I am trying to restart an un-steady calculation with version 2.0.3
Despite the fact I am using: RESTART_SOL= YES MG_DAMP_RESTRICTION= 0.9 %RESTART_FLOW_FILENAME= restart_flow.dat RESTART_FLOW_FILENAME= ./restart_flow.dat RESTART_ADJ_FILENAME= restart_adj.dat RESTART_LIN_FILENAME= restart_lin.dat SU2 cannot find the restart file, which i created by re-naming the latest solution file. Restart flow file name: restart_flow.dat. There is no flow restart file!! the full log is enclosed Aldo |
April 24, 2013, 10:21 |
Sub-directories...
David Tucker
Rep Power: 13 |
Yeah, I tried making sub-directories in the past without much luck. The easiest thing would be to move your restart file up a level so that it is in the same directory as your *.cfg file and *.su2 mesh.
April 26, 2013, 04:58 |
Manuel Cellarius
Rep Power: 13 |
I had the same problem for transient simulations (not steady). It seems that SU2 needs for transient restart simulations also the latest "solution_flow_0000x.dat" file.
Try to rename the latest restart_flow_0000x.dat file to solution_flow_0000x.dat and also copy that one to solution_flow dat. The information in both files is of course the same but in my case that worked. Hope thats helps Manuel |
May 2, 2013, 13:43 |
Santiago Padron
Rep Power: 12 |
By default when restarting a solution the code will look for solution_flow.dat in the config file
% Restart flow input file SOLUTION_FLOW_FILENAME= solution_flow.dat So you can either copy/move the restart_flow.dat to solution_flow.dat or you can modify the configuration file to % Restart flow input file SOLUTION_FLOW_FILENAME= restart_flow.dat For the unsteady case the step at which the code will restart depends on the configuration file option EXT_ITER. So if you want to restart from solution_flow_00099.dat you will have to specify % Number of total iterations EXT_ITER= 100 % Restart flow input file SOLUTION_FLOW_FILENAME= solution_flow.dat Santiago |
conduction problem | venkataramana | OpenFOAM | 3 | December 1, 2013 07:30 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Backup & Restart problem | Sally | CFX | 4 | November 19, 2005 12:44 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
