-   SU2 (http://www.cfd-online.com/Forums/su2/)
-   -   SU2 runtime error: cannot find value of GMRES in given map (http://www.cfd-online.com/Forums/su2/117037-su2-runtime-error-cannot-find-value-gmres-given-map.html)
bruzerravi May 1, 2013 00:48
This variable GMRES occurs in the file: turb_ONERAM6.cfg
% ------------------------ LINEAR SOLVER DEFINITION ---------------------------%
% Linear solver for the implicit (or discrete adjoint) formulation (LU_SGS, SYM_GAUSS_SEIDEL,
% BCGSTAB, GMRES)
LINEAR_SOLVER= GMRES
and when I run SU2_CFD.exe as instructed in the tutorial, I get the above error message.
I also find that the "LINEAR SOLVER DEFINITION" block does not occur anywhere in the file config_template.cfg
Ravi
bruzerravi May 1, 2013 07:11
SU2 serial version runtime error: cannot find value GMRES in given map
I guessed that it could be an error thrown up by use of wrong version. Replacing 1.1 by 2.0 , i found that the inviscid ONERAM6 case works fine.
