-   SU2 (http://www.cfd-online.com/Forums/su2/)
-   -   Spalart Allmaras Gamma Re Theta Model (http://www.cfd-online.com/Forums/su2/117511-spalart-allmaras-gamma-re-theta-model.html)
taxalian May 9, 2013 14:14
Hi SU2 Users,
I have tried to compute the NREL S-series wind turbine airfoil s809 test case available in SU2 v2.0.3 developers release.
The transition model implemented seems to be the γ−Reθt−SA model, introduced by Medida et al.
The problem is that the simulation diverges everytime few iterations and the residual of SA-eddy viscosity results in nan.
I tried to adjust the intermittency factor and the freestream turbulence intensity but does not help at all. I think this should not be the case normally at AoA=0.
May be the model is not yet implemented completely or i don't what other issues causes the simulation not to converge.
May be it's also a good idea if we can have an input parameter that defines the freestream viscosity ratio i.e. mu_turb / mu_lam
Waiting for your reply.
Thanks in advance.
aniketaranake May 14, 2013 13:36
Dear Taxalian,
The transition model is not yet fully implemented and is not ready for use. Sorry for the inconvenience.
Regards,
Aniket
taxalian May 14, 2013 14:58
Hi Aniket,
Thanks for the reply and info. Hope this will be available in the SU2 regular version release.
taxalian October 4, 2013 04:45
γ−Reθt−SA/SST turbulence model
Is the γ−Reθt−SA/SST turbulence model available in github is in fully functional mode now. I tried to run again the similar test case mentioned earlier in this thread, but no success. The code just stopped after performing Mulitgrid agglomeration.
