-   SU2 (http://www.cfd-online.com/Forums/su2/)
-   -   Tecplot can't open SU2 results (http://www.cfd-online.com/Forums/su2/118372-tecplot-cant-open-su2-results.html)
nuaawubin May 26, 2013 07:26
1 Attachment(s)
I try the NACA0012 example,and it end normally,but when i use the tecplot to open the .plt file(flow.dat and surface_flow.plt),error occurrs。
can anyone help to solve this probelm,thks.
taxalian May 27, 2013 01:26
Hi nuaawubin,
It seems that you try to read the history file using tecplot. This normally happens, when you stop the simulation manually or the solution does not converge normally.
SergeAS May 27, 2013 04:11
Which tecplot version are you using ?
Older versions of tecplot do not understand "NODES=" and "ELEMENTS=" directives in ASCII file. Just try to change directives in to the short form: "N=" and "E="
nuaawubin May 27, 2013 11:05
thks,you are right
you are right,it caused by the tecplot version,thks.:)
