Errors running Caradonna (rotating blade) test case
I'm still learning, so probably i'm missing something obvious. When I try to run the caradonna test case, it shows a lot of points with negative pressure and then start iterations, every iteration says "nan". The original test case configuration file looked for a mesh file with a slightly different name, so I changed that. Everything else is equal. Anyone have any idea what may be wrong? Thank you!! |
Sorry that you have found some problems with the Caradonna test case. Unfortunately, this configuration file (and mesh) are a bit outdated and, because we have recently changed the periodic boundary conditions, it is unlikely that this case will work with the later versions of the code (2.0+). You might try running this case with version 1.0 of the code. Apologies and all the best, Tom |
