June 11, 2013, 21:50 |
job aborted when come to write solution file
cean wang
I just compiled 2.0.4 against MPICH2 on win7@32 with gcc for win. When trying the Euler/naca0012 case with 8 cores, the program stopped when it needs to write solution file. I set: Code:
% Writing solution file frequency WRT_SOL_FREQ= 100 Code:
job aborted: rank: node: exit code[: error message] 0: pcname: -1073741819: process 0 exited without calling finalize 1: ...AS ABOVE ... 7: ... Any suggestion? Regards, Cean |
June 28, 2013, 19:23 |
Thomas D. Economon
Hi Cean,
Not sure if it will address your current issue, but could you please try again with version 2.0.5? We made some changes to the solution output routines, in general. If not, it may be a platform specific issue. Cheers, Tom |
June 28, 2013, 21:05 |
#3 | |
Cean
I traced to the line which can't run and added one output line. Then it has no problem now. Sometimes the compiler is strange. Regards, Cean |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
[swak4Foam] problem on installing swak4Foam | navid2 | OpenFOAM Community Contributions | 2 | May 30, 2012 04:32 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
