Home > Forums > Software User Forums > SU2
Problems with SU2_SMC
Old   June 26, 2013, 07:35
Default Problems with SU2_SMC
Fang Liang
Fang-SIAMM is on a distinguished road
HI, everyone.
I'm using the SU2v2.0.4 to test the sliding mesh problem, but there are some questions as follows:
How do I define the MARKER_SLIDING in the configure file. Is the defination below right?
MARKER_SLIDING = ( inter-in,inter-out,inter-out,inter-in,0,1,1,0 ).
For Zone0, inter-in is the sliding boundary, while inter-out in Zone1 is the donor marker.
I'm trying to test the case in AIAA-2013-0632.
Thanks for help.
Fang
Fang-SIAMM is offline   Reply With Quote
Old   June 28, 2013, 19:06
Thomas D. Economon
economon is on a distinguished road
Hi Fang,
Great to hear that you're interested in the sliding mesh code! Unfortunately, we are still actively developing most of the sliding mesh machinery, and it is in the process of changing quite a bit due to other improvements we are making for parallelism, etc.
That being said, the unsteady adjoint for euler flows on single block meshes is functional. The same pitching airfoil case described in the paper should work with the most recent version of the code. Please feel free to contact me, if you would like some more info.
Cheers,
Tom
economon is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[mesh manipulation] Problems with rotational cyclic boundaries TReviol OpenFOAM Meshing & Mesh Conversion 8 July 11, 2014 03:45
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 06:44
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 05:44
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 11:00
