Home > Forums > Software User Forums > SU2
Creating a custom objective function
Old   May 7, 2013, 08:02
Default Creating a custom objective function
viit3 is on a distinguished road
Through a cursory glance at the code, I can see that objective functions go into the adjoint implementation in adjoint_solution_mean. Is that the only place where objective functions go/
I wanted to implement a custom objective function for pressure recovery for internal flows. How would I go about doing that?
viit3 is offline   Reply With Quote
Old   May 12, 2013, 11:04
Francisco Palacios
fpalacios is on a distinguished road
As you know, SU2 design uses the continuous adjoint methodology, more details in:
http://www.stanford.edu/~fasispg/art...-2013-0287.pdf
http://adl.stanford.edu/papers/AIAA-2012-3018.pdf
http://www.stanford.edu/~fasispg/art..._March2012.pdf
http://www.stanford.edu/~fasispg/art...urnal_2009.pdf
http://www.stanford.edu/~fasispg/art...urnal_2007.pdf
A new objective function will require changes in the adjoint boundary conditions:
void CAdjEulerSolution::SetForceProj_Vector(CGeometry *geometry, CSolution **solution_container, CConfig *config)
and in the formula for computing the surface sensitivity.
void CAdjEulerSolution::Inviscid_Sensitivity(CGeometry *geometry, CSolution **solution_container, CNumerics *solver, CConfig *config)
Currently we are working on a discrete and a hybrid adjoint (it will be finished at the end of the year).
Thank you for you interest in SU2,
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   July 3, 2013, 07:22
I was going through some of the literature.
From what I understand, the formulation only takes surface integrals as an objective which is specified in
Is that correct?
I don't understand what I have to change in
since the only term related to the objective function is d which is coming from SetForceProj_Vector.
Again, is this statement correct?
For an initial attempt, I want to do an incompressible Euler optimization. Is that possible?
Thank you for all the help.
adjoint, objective function
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 10:20
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
Force Report help~ or maybe Custom Field Function sailor FLUENT 0 April 13, 2011 03:45
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
