June 7, 2015, 08:50 |
Problems launching adjoint
I'm working on a single nozzle case. After I converged in direct 2nd order, I tried to launch the adjoint, but I have an error message that can be seen here. Code:
CSysSolve::FGMRES(): system solved by initial guess. I tried to do adjoint with the testcases from SU2 and it worked, so I don't understand where my problem is... I put my cfg file here-under, if someone could help me it would be great!! Thanks a lot Max Code:
% Physical governing equations (EULER, NAVIER_STOKES, % TNE2_EULER, TNE2_NAVIER_STOKES, % WAVE_EQUATION, HEAT_EQUATION, LINEAR_ELASTICITY, % POISSON_EQUATION) PHYSICAL_PROBLEM= NAVIER_STOKES % % Specify turbulence model (NONE, SA, SA_NEG, SST) KIND_TURB_MODEL= SST % % Mathematical problem (DIRECT, ADJOINT) MATH_PROBLEM= ADJOINT AXISYMMETRIC= YES % % Restart solution (NO, YES) RESTART_SOL= NO % % Regime type (COMPRESSIBLE, INCOMPRESSIBLE) REGIME_TYPE= COMPRESSIBLE % % System of measurements (SI, US) % International system of units (SI): ( meters, kilograms, Kelvins, % Newtons = kg m/s^2, Pascals = N/m^2, % Density = kg/m^3, Speed = m/s, % Equiv. Area = m^2 ) % United States customary units (US): ( inches, slug, Rankines, lbf = slug ft/s^2, % psf = lbf/ft^2, Density = slug/ft^3, % Speed = ft/s, Equiv. Area = ft^2 ) SYSTEM_MEASUREMENTS= SI % -------------------- COMPRESSIBLE FREE-STREAM DEFINITION --------------------% % % Mach number (non-dimensional, based on the free-stream values) MACH_NUMBER= 0.10 % % Damping factor for fixed CL mode (0.1 by default) DAMP_FIXED_CL= 0.2 % % Init option to choose between Reynolds (default) or thermodynamics quantities % for initializing the solution (REYNOLDS, TD_CONDITIONS) INIT_OPTION= TD_CONDITIONS % % Free-stream option to choose between density and temperature (default) for % initializing the solution (TEMPERATURE_FS, DENSITY_FS) FREESTREAM_OPTION= TEMPERATURE_FS FREESTREAM_TURBULENCEINTENSITY = 0.001 % % Free-stream pressure (101325.0 N/m^2, 2116.216 psf by default) FREESTREAM_PRESSURE= 98250.29 % % Free-stream temperature (288.15 K, 518.67 R by default) FREESTREAM_TEMPERATURE= 294.261 % % -------------------- INCOMPRESSIBLE FREE-STREAM DEFINITION ------------------% % % Free-stream density (1.2886 Kg/m^3, 0.0025 slug/ft^3 by default) FREESTREAM_DENSITY= 1.2886 % % Free-stream velocity (1.0 m/s, 1.0 ft/s by default) FREESTREAM_VELOCITY= ( 1.0, 0.00, 0.00 ) % % Free-stream viscosity (1.853E-5 N s/m^2, 3.87E-7 lbf s/ft^2 by default) FREESTREAM_VISCOSITY= 1.853E-5 % ---------------------- REFERENCE VALUE DEFINITION ---------------------------% % % Reference origin for moment computation (m or in) REF_ORIGIN_MOMENT_X = 0.25 REF_ORIGIN_MOMENT_Y = 0.00 REF_ORIGIN_MOMENT_Z = 0.00 % % Reference length for pitching, rolling, and yawing non-dimensional % moment (m or in) REF_LENGTH_MOMENT= 1.0 % % Reference area for force coefficients (0 implies automatic % calculation) (m^2 or in^2) REF_AREA= 1.0 % % Flow non-dimensionalization (DIMENSIONAL, FREESTEAM_PRESS_EQ_ONE, % FREESTEAM_VEL_EQ_MACH, FREESTEAM_VEL_EQ_ONE) REF_DIMENSIONALIZATION= DIMENSIONAL % ---- IDEAL GAS, POLYTROPIC, VAN DER WAALS AND PENG ROBINSON CONSTANTS -------% % % Different gas model (STANDARD_AIR, IDEAL_GAS, VW_GAS, PR_GAS) FLUID_MODEL= STANDARD_AIR % % Ratio of specific heats (1.4 default and the value is hardcoded % for the model STANDARD_AIR) GAMMA_VALUE= 1.4 % % Specific gas constant (287.058 J/kg*K default and this value is hardcoded % for the model STANDARD_AIR) GAS_CONSTANT= 287.058 % % Critical Temperature (131.00 K by default) CRITICAL_TEMPERATURE= 131.00 % % Critical Pressure (3588550.0 N/m^2 by default) CRITICAL_PRESSURE= 3588550.0 % % Critical Density (263.0 Kg/m3 by default) CRITICAL_DENSITY= 263.0 % % Acentri factor (0.035 (air)) ACENTRIC_FACTOR= 0.035 % --------------------------- VISCOSITY MODEL ---------------------------------% % % Viscosity model (SUTHERLAND, CONSTANT_VISCOSITY). VISCOSITY_MODEL= SUTHERLAND % % Molecular Viscosity that would be constant (1.716E-5 by default) MU_CONSTANT= 1.716E-5 % % Sutherland Viscosity Ref (1.716E-5 default value for AIR SI) MU_REF= 1.716E-5 % % Sutherland Temperature Ref (273.15 K default value for AIR SI) MU_T_REF= 273.15 % % Sutherland constant (110.4 default value for AIR SI) SUTHERLAND_CONSTANT= 110.4 % --------------------------- THERMAL CONDUCTIVITY MODEL ----------------------% % % Conductivity model (CONSTANT_CONDUCTIVITY, CONSTANT_PRANDTL). CONDUCTIVITY_MODEL= CONSTANT_PRANDTL % % Molecular Thermal Conductivity that would be constant (0.0257 by default) KT_CONSTANT= 0.0257 % -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % % Navier-Stokes (no-slip), constant heat flux wall marker(s) (NONE = no marker) % Format: ( marker name, constant heat flux (J/m^2), ... ) MARKER_HEATFLUX= ( WALL, 0, OUTSIDE, 0, SLIP_WALL, 0) % % Far-field boundary marker(s) (NONE = no marker) MARKER_FAR= ( FAR_FIELD ) % % Symmetry boundary marker(s) (NONE = no marker) MARKER_SYM= ( AXIS ) % % Inlet boundary type (TOTAL_CONDITIONS, MASS_FLOW) INLET_TYPE= TOTAL_CONDITIONS % MARKER_INLET= ( INLET, 294.26, 242695.4604, 1, 0, 0 ) % % ------------------------ SURFACES IDENTIFICATION ----------------------------% % % Marker(s) of the surface in the surface flow solution file MARKER_PLOTTING = ( WALL ) % % Marker(s) of the surface where the non-dimensional coefficients are evaluated. MARKER_MONITORING = ( WALL ) % % Marker(s) of the surface where obj. func. (design problem) will be evaluated MARKER_DESIGNING = ( WALL ) % ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------% % % Numerical method for spatial gradients (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES) NUM_METHOD_GRAD= GREEN_GAUSS % % CFL number (stating value for the adaptive CFL number) CFL_NUMBER= 2 % % Adaptive CFL number (NO, YES) CFL_ADAPT= NO % % Parameters of the adaptive CFL number (factor down, factor up, CFL min value, % CFL max value ) CFL_ADAPT_PARAM= ( 1.5, 0.5, 0.5, 100.0 ) % % Maximum Delta Time in local time stepping simulations MAX_DELTA_TIME= 1E6 % % Runge-Kutta alpha coefficients RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 ) % OBJECTIVE_FUNCTION= MASS_FLOW_RATE % ----------------------- SLOPE LIMITER DEFINITION ----------------------------% % % Reference element length for computing the slope and sharp edges % limiters (0.1 m, 5.0 in by default) REF_ELEM_LENGTH= 0.1 % % Coefficient for the limiter LIMITER_COEFF= 0.3 % % Freeze the value of the limiter after a number of iterations LIMITER_ITER= 999999 % % Coefficient for the sharp edges limiter SHARP_EDGES_COEFF= 3.0 % % Reference coefficient (sensitivity) for detecting sharp edges. REF_SHARP_EDGES= 3.0 % % Remove sharp edges from the sensitivity evaluation (NO, YES) SENS_REMOVE_SHARP= NO % ------------------------ LINEAR SOLVER DEFINITION ---------------------------% % % Linear solver or smoother for implicit formulations (BCGSTAB, FGMRES, SMOOTHER_JACOBI, % SMOOTHER_ILU0, SMOOTHER_LUSGS, % SMOOTHER_LINELET) LINEAR_SOLVER= FGMRES % % Preconditioner of the Krylov linear solver (ILU0, LU_SGS, LINELET, JACOBI) LINEAR_SOLVER_PREC= JACOBI % % Minimum error of the linear solver for implicit formulations LINEAR_SOLVER_ERROR= 1E-6 % % Max number of iterations of the linear solver for the implicit formulation LINEAR_SOLVER_ITER= 10 % -------------------------- MULTIGRID PARAMETERS -----------------------------% % % Multi-grid levels (0 = no multi-grid) MGLEVEL= 3 % % Multi-grid cycle (V_CYCLE, W_CYCLE, FULLMG_CYCLE) MGCYCLE= V_CYCLE % % Multi-grid pre-smoothing level MG_PRE_SMOOTH= ( 1, 2, 3, 3 ) % % Multi-grid post-smoothing level MG_POST_SMOOTH= ( 0, 0, 0, 0 ) % % Jacobi implicit smoothing of the correction MG_CORRECTION_SMOOTH= ( 0, 0, 0, 0 ) % % Damping factor for the residual restriction MG_DAMP_RESTRICTION= 0.75 % % Damping factor for the correction prolongation MG_DAMP_PROLONGATION= 0.75 % -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------% % % Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC, % TURKEL_PREC, MSW) CONV_NUM_METHOD_FLOW= JST % % Spatial numerical order integration (1ST_ORDER, 2ND_ORDER, 2ND_ORDER_LIMITER) SPATIAL_ORDER_FLOW= 1ST_ORDER % % Slope limiter (VENKATAKRISHNAN, BARTH_JESPERSEN) SLOPE_LIMITER_FLOW= VENKATAKRISHNAN % % Entropy fix coefficient (0.0 implies no entropy fixing, 1.0 implies scalar % artificial dissipation) ENTROPY_FIX_COEFF= 0.0 % % 1st, 2nd and 4th order artificial dissipation coefficients AD_COEFF_FLOW= ( 0.15, 0.5, 0.02 ) % TIME_DISCRE_FLOW= EULER_IMPLICIT % RELAXATION_FACTOR_FLOW= 1.0 RELAXATION_FACTOR_TURB= 1.0 % -------------------- TURBULENT NUMERICAL METHOD DEFINITION ------------------% % % Convective numerical method (SCALAR_UPWIND) CONV_NUM_METHOD_TURB= SCALAR_UPWIND % % Spatial numerical order integration (1ST_ORDER, 2ND_ORDER, 2ND_ORDER_LIMITER) SPATIAL_ORDER_TURB= 1ST_ORDER % % Slope limiter (VENKATAKRISHNAN) SLOPE_LIMITER_TURB= VENKATAKRISHNAN % % Viscous limiter (NO, YES) VISCOUS_LIMITER_TURB= NO % % Time discretization (EULER_IMPLICIT) TIME_DISCRE_TURB= EULER_IMPLICIT % % Reduction factor of the CFL coefficient in the turbulence problem CFL_REDUCTION_TURB= 1.0 % % --------------------- HEAT NUMERICAL METHOD DEFINITION ----------------------% % % Value of the thermal diffusivity THERMAL_DIFFUSIVITY= 1.0 % ---------------- ADJOINT-FLOW NUMERICAL METHOD DEFINITION -------------------% % % Convective numerical method (JST, LAX-FRIEDRICH, ROE) CONV_NUM_METHOD_ADJFLOW= JST % % Spatial numerical order integration (1ST_ORDER, 2ND_ORDER, 2ND_ORDER_LIMITER) SPATIAL_ORDER_ADJFLOW= 2ND_ORDER % % Slope limiter (VENKATAKRISHNAN, SHARP_EDGES, WALL_DISTANCE) SLOPE_LIMITER_ADJFLOW= VENKATAKRISHNAN % % 1st, 2nd, and 4th order artificial dissipation coefficients AD_COEFF_ADJFLOW= ( 0.15, 0.5, 0.02 ) % % Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT) TIME_DISCRE_ADJFLOW= EULER_IMPLICIT % % Relaxation coefficient RELAXATION_FACTOR_ADJFLOW= 1.0 % % Reduction factor of the CFL coefficient in the adjoint problem CFL_REDUCTION_ADJFLOW= 0.8 % % Limit value for the adjoint variable LIMIT_ADJFLOW= 1E6 % % Multigrid adjoint problem (NO, YES) MG_ADJFLOW= YES % ----------------------- GEOMETRY EVALUATION PARAMETERS ----------------------% % % Geometrical evaluation mode (FUNCTION, GRADIENT) GEO_MODE= FUNCTION % % Marker(s) of the surface where geometrical based func. will be evaluated GEO_MARKER= ( WALL ) % % Number of airfoil sections GEO_NUMBER_SECTIONS= 5 % % Orientation of airfoil sections (X_AXIS, Y_AXIS, Z_AXIS) GEO_ORIENTATION_SECTIONS= X_AXIS % % Location (coordinate) of the airfoil sections (MinValue, MaxValue) GEO_LOCATION_SECTIONS= (0, 58334022835022 ) % % Plot loads and Cp distributions on each airfoil section GEO_PLOT_SECTIONS= NO % % Number of section cuts to make when calculating internal volume GEO_VOLUME_SECTIONS= 101 % ------------------------- GRID ADAPTATION STRATEGY --------------------------% % % Kind of grid adaptation (NONE, PERIODIC, FULL, FULL_FLOW, GRAD_FLOW, FULL_ADJOINT, % GRAD_ADJOINT, GRAD_FLOW_ADJ, ROBUST, % FULL_LINEAR, COMPUTABLE, COMPUTABLE_ROBUST, % REMAINING, WAKE, SMOOTHING, SUPERSONIC_SHOCK) KIND_ADAPT= FULL_FLOW % % Percentage of new elements (% of the original number of elements) NEW_ELEMS= 5 % % Scale factor for the dual volume DUALVOL_POWER= 0.5 % % Adapt the boundary elements (NO, YES) ADAPT_BOUNDARY= YES % ----------------------- DESIGN VARIABLE PARAMETERS --------------------------% % DV_KIND= FFD_SETTING % % Marker of the surface in which we are going apply the shape deformation DV_MARKER= ( WALL ) % DV_PARAM= ( 1, 0.5 ) % % Value of the shape deformation DV_VALUE= 0.01 % ------------------------ GRID DEFORMATION PARAMETERS ------------------------% % % Linear solver or smoother for implicit formulations (FGMRES, RESTARTED_FGMRES, BCGSTAB) DEFORM_LINEAR_SOLVER= FGMRES % % Number of smoothing iterations for mesh deformation DEFORM_LINEAR_ITER= 500 % % Number of nonlinear deformation iterations (surface deformation increments) DEFORM_NONLINEAR_ITER= 2 % % Print the residuals during mesh deformation to the console (YES, NO) DEFORM_CONSOLE_OUTPUT= NO % % Factor to multiply smallest cell volume for deform tolerance (0.001 default) DEFORM_TOL_FACTOR = 0.001 % % Type of element stiffness imposed for FEA mesh deformation (INVERSE_VOLUME, % WALL_DISTANCE, CONSTANT_STIFFNESS) DEFORM_STIFFNESS_TYPE= INVERSE_VOLUME % % Visualize the deformation (NO, YES) VISUALIZE_DEFORMATION= NO % -------------------- FREE-FORM DEFORMATION PARAMETERS -----------------------% % % Tolerance of the Free-Form Deformation point inversion FFD_TOLERANCE= 1E-10 % % Maximum number of iterations in the Free-Form Deformation point inversion FFD_ITERATIONS= 500 % FFD_DEFINITION= (MAIN_BOX, 0.5, 0.25, -0.25, 1.5, 0.25, -0.25, 1.5, 0.75, -0.25, 0.5, 0.75, -0.25, 0.5, 0.25, 0.25, 1.5, 0.25, 0.25, 1.5, 0.75, 0.25, 0.5, 0.75, 0.25) % % FFD box degree: 3D case (x_degree, y_degree, z_degree) % 2D case (x_degree, y_degree, 0) FFD_DEGREE= (10, 10, 1) % % Surface continuity at the intersection with the FFD (1ST_DERIVATIVE, 2ND_DERIVATIVE) FFD_CONTINUITY= 2ND_DERIVATIVE % --------------------------- CONVERGENCE PARAMETERS --------------------------% % % Number of total iterations EXT_ITER= 25000 % % Convergence criteria (CAUCHY, RESIDUAL) % CONV_CRITERIA= CAUCHY % % Residual reduction (order of magnitude with respect to the initial value) RESIDUAL_REDUCTION= 5 % % Min value of the residual (log10 of the residual) RESIDUAL_MINVAL= -8 % % Start convergence criteria at iteration number STARTCONV_ITER= 10 % % Number of elements to apply the criteria CAUCHY_ELEMS= 100 % % Epsilon to control the series convergence CAUCHY_EPS= 1E-6 % % Direct function to apply the convergence criteria (LIFT, DRAG, NEARFIELD_PRESS) CAUCHY_FUNC_FLOW= LIFT % % Adjoint function to apply the convergence criteria (SENS_GEOMETRY, SENS_MACH) CAUCHY_FUNC_ADJFLOW= SENS_GEOMETRY % ------------------------- INPUT/OUTPUT INFORMATION --------------------------% % % Mesh input file MESH_FILENAME= ASME_150.su2 % % Mesh input file format (SU2, CGNS) MESH_FORMAT= SU2 % % Mesh output file MESH_OUT_FILENAME= mesh_out.su2 % % Restart flow input file SOLUTION_FLOW_FILENAME= restart_flow.dat % % Restart adjoint input file SOLUTION_ADJ_FILENAME= solution_adj.dat % % Output file format (TECPLOT, TECPLOT_BINARY, PARAVIEW, % FIELDVIEW, FIELDVIEW_BINARY) OUTPUT_FORMAT= PARAVIEW % % Output file convergence history (w/o extension) CONV_FILENAME= history % % Output file with the forces breakdown BREAKDOWN_FILENAME= forces_breakdown.dat % % Output file restart flow RESTART_FLOW_FILENAME= restart_flow.dat % % Output file restart adjoint RESTART_ADJ_FILENAME= restart_adj.dat % % Output file flow (w/o extension) variables VOLUME_FLOW_FILENAME= flow % % Output file adjoint (w/o extension) variables VOLUME_ADJ_FILENAME= adjoint % % Output Objective function VALUE_OBJFUNC_FILENAME= of_eval.dat % % Output objective function gradient (using continuous adjoint) GRAD_OBJFUNC_FILENAME= of_grad.dat % % Output file surface flow coefficient (w/o extension) SURFACE_FLOW_FILENAME= surface_flow % % Output file surface adjoint coefficient (w/o extension) SURFACE_ADJ_FILENAME= surface_adjoint % % Writing solution file frequency WRT_SOL_FREQ= 200 % % Writing solution file frequency for physical time steps (dual time) WRT_SOL_FREQ_DUALTIME= 1 % % Writing convergence history frequency WRT_CON_FREQ= 1 % % Writing convergence history frequency (dual time, only written to screen) WRT_CON_FREQ_DUALTIME= 25 % % Output residual values in the solution files WRT_RESIDUALS= YES % % Output limiters values in the solution files WRT_LIMITERS= NO % % Output the sharp edges detector WRT_SHARPEDGES= YES % % Minimize the required output memory LOW_MEMORY_OUTPUT= NO % % Verbosity of console output: NONE removes minor MPI overhead (NONE, HIGH) CONSOLE_OUTPUT_VERBOSITY= HIGH % --------------------- OPTIMAL SHAPE DESIGN DEFINITION -----------------------% % % Optimization objective function with scaling factor % ex= Objective * Scale OPT_OBJECTIVE= DRAG * 0.001 % % Optimization constraint functions with scaling factors, separated by semicolons % ex= (Objective = Value ) * Scale, use '>','<','=' OPT_CONSTRAINT= ( LIFT > 0.328188 ) * 0.001; ( MOMENT_Z > 0.034068 ) * 0.001; ( MAX_THICKNESS > 0.11 ) * 0.001 % % Maximum number of iterations OPT_ITERATIONS= 100 % % Requested accuracy OPT_ACCURACY= 1E-6 % % Lower and upper bound for each design variable BOUND_DV= 0.1 % % Optimization design variables, separated by semicolons DEFINITION_DV= ( 1, 1.0 | airfoil | 0, 0.05 ); ( 1, 1.0 | airfoil | 0, 0.10 ); ( 1, 1.0 | airfoil | 0, 0.15 ); ( 1, 1.0 | airfoil | 0, 0.20 ); ( 1, 1.0 | airfoil | 0, 0.25 ); ( 1, 1.0 | airfoil | 0, 0.30 ); ( 1, 1.0 | airfoil | 0, 0.35 ); ( 1, 1.0 | airfoil | 0, 0.40 ); ( 1, 1.0 | airfoil | 0, 0.45 ); ( 1, 1.0 | airfoil | 0, 0.50 ); ( 1, 1.0 | airfoil | 0, 0.55 ); ( 1, 1.0 | airfoil | 0, 0.60 ); ( 1, 1.0 | airfoil | 0, 0.65 ); ( 1, 1.0 | airfoil | 0, 0.70 ); ( 1, 1.0 | airfoil | 0, 0.75 ); ( 1, 1.0 | airfoil | 0, 0.80 ); ( 1, 1.0 | airfoil | 0, 0.85 ); ( 1, 1.0 | airfoil | 0, 0.90 ); ( 1, 1.0 | airfoil | 0, 0.95 ); ( 1, 1.0 | airfoil | 1, 0.05 ); ( 1, 1.0 | airfoil | 1, 0.10 ); ( 1, 1.0 | airfoil | 1, 0.15 ); ( 1, 1.0 | airfoil | 1, 0.20 ); ( 1, 1.0 | airfoil | 1, 0.25 ); ( 1, 1.0 | airfoil | 1, 0.30 ); ( 1, 1.0 | airfoil | 1, 0.35 ); ( 1, 1.0 | airfoil | 1, 0.40 ); ( 1, 1.0 | airfoil | 1, 0.45 ); ( 1, 1.0 | airfoil | 1, 0.50 ); ( 1, 1.0 | airfoil | 1, 0.55 ); ( 1, 1.0 | airfoil | 1, 0.60 ); ( 1, 1.0 | airfoil | 1, 0.65 ); ( 1, 1.0 | airfoil | 1, 0.70 ); ( 1, 1.0 | airfoil | 1, 0.75 ); ( 1, 1.0 | airfoil | 1, 0.80 ); ( 1, 1.0 | airfoil | 1, 0.85 ); ( 1, 1.0 | airfoil | 1, 0.90 ); ( 1, 1.0 | airfoil | 1, 0.95 ) |
July 14, 2015, 17:27 |
Thomas D. Economon
Rep Power: 14 |
It is possible that the simulation is simply going unstable immediately upon launch. Have you tried turning off multigrid, lowering the CFL, switching to 1st order, etc., just to see if you are able to get it running first? If you can get it working under these scenarios, then try ramping the convergence acceleration back up. Hope this helps, Tom |
March 12, 2016, 11:32 |
Mike
Rep Power: 10 |
Any luck finding a solution to this?
I'm running into the same problem for a hypersonic inlet case and have tried reducing the CFL number to very low numbers (0.001) and running the adjoint first order but it still diverges after the first iteration. I can't work out why its happening as the direct solution has converged fine. I assume I'm running it right... parallel_computation script with MATH_PROBLEM= CONTINUOUS_ADJOINT in the config file and the direct simulation restart file as the input. |
adjoint solver, nozzle simulation, su2 error |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
Adjoint solver for flow problems | jelmer | OpenFOAM Running, Solving & CFD | 11 | March 12, 2017 06:52 |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 12:13 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 05:44 |
Help required to solve Hydraulic related problems | aero | CFX | 0 | October 30, 2006 11:00 |
