November 2, 2013, 07:18 |
segmentation fault
wangjian
Rep Power: 12 |
I have recently started using SU2 for my research work. I have the following question: I used the pointwise software to generate a 2D mesh of SU2 format.But when I used the SU2 to compute the airfoil,it always appeared segmentation fault while it got to the solution preprocessing.How should I deal with the problem. Thanks, Mandar |
November 3, 2013, 21:16 |
#2 | |
Francisco Palacios
Rep Power: 15 |
Best, Francisco |
November 3, 2013, 22:01 |
#3 | |
wangjian
Rep Power: 12 |
I am using the SU2v2.0 and the config file is the inv_NACA0012.cfg.I used pointwise software to build a unstructed mesh for NACA6412 airfoil and changed the boundary condition definition of config file to be consistent with the definition in the pointwise.However,when I used the SU2 to compute,it always appeared segmentation fault. Thanks. |
December 12, 2013, 08:22 |
#4 | |
Mandar Kulkarni
Rep Power: 12 |
I think in your post dated November 2, 2013, 07:18 you copy-pasted one of my messages along with my name! Mandar Kulkarni |
Display Modes | |
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel | francesco | OpenFOAM Bugs | 4 | May 2, 2017 22:59 |
Segmentation Fault w/ compiled OF 2.2.0 - motorBike example | sudo | OpenFOAM Running, Solving & CFD | 3 | April 2, 2013 18:27 |
segmentation fault when installing OF-2.1.1 on a cluster | Rebecca513 | OpenFOAM Installation | 9 | July 31, 2012 16:06 |
Segmentation Fault | Shawn_A | OpenFOAM Running, Solving & CFD | 6 | October 31, 2011 15:38 |
ParaView segmentation fault only for multiphase | gwierink | OpenFOAM | 9 | March 25, 2010 08:23 |
