Home > Forums > SU2
Surface_Sensitivity variable in surface_adjoint file
Old   January 29, 2014, 23:08
Default Surface_Sensitivity variable in surface_adjoint file
Tommy Chen
Tommy Chen is on a distinguished road
Hi Stanford guys
I have run a continuous adjoint computation of the RAE2822 airfoil in the test cases.
In the surface_adjoint.dat file and the surface_adjoint.csv file, I found that the surface_sensitivity variable is a one dimensional scalar instead of a 2D vector?
Why is the surface sensitivity of 2D airfoil scalar instead of vector ?
Many thanks
Tommy Chen is offline   Reply With Quote
Old   January 29, 2014, 23:41
Tommy Chen
So is this 1D surface_sensitivity variable the absolute value of the 2D gradient vector?
If then , what is the variable that difines the direction of the gradient?
Old   January 30, 2014, 01:58
Francisco Palacios
fpalacios is on a distinguished road
In this link your will find a good reference of the implementation https://adl.stanford.edu/papers/AIAA..._March2012.pdf
Anyway, the computed sensitivity is with respect to displacements in the normal direction. So it is always an scalar... e.g. how change the drag of the aircraft when you move a point on the surface in the normal direction to the surface.
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   January 30, 2014, 09:41
Tommy Chen
Originally Posted by fpalacios View Post
Best,
Francisco
Thanks Francisco,
So if the swept angle of the wing or the span and chord length of the wing are also design variables,which leads to the change in the plan form, then the normal-to-surface sensitivity is still all that we need to calculate the gradient of the objective function ?
Old   January 30, 2014, 21:14
Francisco Palacios
Thanks Francisco,
Yes, it is going to work, and the gradient in the normal direction is everything that you need. The only thing that you should keep in mind is that the sensitivity on geometrical singularities is not right so... some small inaccuracies are expected if you move singular points (fix or round leading edges is a good idea to avoid that situation).
Best,
Francisco
Old   January 30, 2014, 21:22
Tommy Chen
Best,
Francisco
I get your point, many thanks.
So actually I can use all the normal-to-surface sensitivity and the normal vector (the absolute value of which is the surface element area) to project the gradient to any other design variables developed myself.
Thread Tools
Trackbacks are On
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 94 August 19, 2016 08:14
swak4foam building problem GGerber OpenFOAM Installation 54 April 24, 2015 16:02
wmake compiling new solver mksca OpenFOAM Programming & Development 13 August 18, 2014 22:26
OpenFOAM Installation for navalFoam sachinlb OpenFOAM Installation 21 June 23, 2014 08:07
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
