Home > Forums > Software User Forums > SU2
Unsteady Inlet B.C.
Old   February 2, 2014, 20:39
Default Unsteady Inlet B.C.
lemonice87 is on a distinguished road
Hi All,
Apologies if the question has been answered before, but can you and how do you give unsteady inlet bounday condition, meaning I want to give a decreasing velocity at the inlet boundary as time advances.
Thanks for your help!
lemonice87 is offline   Reply With Quote
Old   February 4, 2014, 20:25
Francisco Palacios
fpalacios is on a distinguished road
Originally Posted by lemonice87 View Post
Hi All,
This is an important topic. If you are interested in wind gust simulation, there is an implementation of a technique that is based in adding virtual grid velocity. This is a useful method, otherwise it is very easy to generate spurious waves and transients.
If the inflow profile changes very slowly with the time, you can directly modify the boundary conditions in solver_direct_mean.cpp subroutine
void CEulerSolver::BC_Inlet(CGeometry *geometry, CSolver **solver_container, CNumerics *conv_numerics, CNumerics *visc_numerics, CConfig *config, unsigned short val_marker)
Remember that config->GetExtIter() gives you the index of the current iteration.
In the past (SU2 v2.0.5) there was an option in SU2 for unsteady_farfield, you can take a look at that version if you are interested.
Thanks for your interest in SU2,
Francisco
fpalacios is offline   Reply With Quote
Old   February 7, 2014, 14:13
Thanks for the help, I will look to both proposed solution.
When you say "If the inflow profile changes very slowly with the time" you mean with respect to my tiume advancment step correct?
Anyway I am simulating a supersonic object slowing down (whilst remaing in supersoninc flow) wouldn't that be less problematic? Especially as I am using the Euler solver for now.
Thanks for the help
Old   February 13, 2014, 01:07
Santiago Padron
Santiago Padron is on a distinguished road
Yes, it will be better to have the inflow profile change slower than the time advancement step.
Yes, simulating the supersonic flow will make the problem less problematic.
Thanks for your interest and lets us know how your implementation goes.
Santiago
Santiago Padron is offline   Reply With Quote
Old   November 16, 2017, 07:50
Misa
mmj_blackforce is on a distinguished road
Francisco
Dear Francisco:
Can you please explain if adding virtual grid velocity is possible in fluent?
Regards
mmj_blackforce is offline   Reply With Quote
unsteady inlet velocity udf jill FLUENT 8 February 10, 2015 06:04
Reusing the inlet time directories in timeVaryingMappedFixedValue ngj_22 OpenFOAM Running, Solving & CFD 0 January 24, 2013 10:22
Using Opening B.C. for both inlet and outlet SH_P CFX 1 June 11, 2012 20:15
which B.C. i should apply for this problem? raivish CFX 0 January 6, 2006 08:47
how to change inlet condition in unsteady flow? bob FLUENT 3 July 12, 2002 18:52
