Explanation for the constraint/objective function key words |
April 12, 2014, 12:38 |
Sreekanth
Rep Power: 12 |
1. What does the objective functions Nearfield pressure, Equivalent Area, Efficiency.. imply? 2. Also, in the other geometric constraint what does Area imply? 3..How can I impose a constraint on the volume of a shape in 3D or correspondingly area in 2D? 4. How to add a new constraint to the code ? Sreekanth |
April 13, 2014, 23:26 |
#2 | |||
Thomas D. Economon
Rep Power: 14 |
Dear Sreekanth,
Some answers embedded below... Quote:
If you are interested in adding new constraints, the main module is SU2_GDC. Please see the CBoundaryGeometry class in geometry_structure.cpp in order to find the current implementations of the constraints. Cheers, Tom |
April 14, 2014, 04:37 |
Sreekanth
Rep Power: 12 |
Thank you, I will try to figure out what is given in SU2_GDC.
April 17, 2014, 07:33 |
#4 | |
Sreekanth
Rep Power: 12 |
Could you tell me something more on how its implemented? I am unable to figure out what is being done in the code. What should I be looking for? Which are the functions that I should modify/ add ? Thank you. Sreekanth |
April 24, 2014, 06:05 |
#5 | |
Thomas D. Economon
Rep Power: 14 |
Hope this helps, T |
Display Modes | |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 11:51 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 07:59 |
function Key | norbinou | Siemens | 3 | May 21, 2007 03:30 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 07:27 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 09:23 |
