Home > Forums > Software User Forums > SU2
unable to run the caradonna blade simulation
Old   May 9, 2014, 08:50
Question unable to run the caradonna blade simulation
deeps is on a distinguished road
Dear All,
I have been trying to run the config file provided for simulating Caradonna and Tsung blade in the rotating frame of reference. I am using SU2 version 2.7. However, I'm unable to run this case. It blows up after around 30 iterations giving non-physical points and gauss elimination error. The residuals diverge right from the beginning and the CL, CD values are constant at -1000.
1. I'm aware about similar posts earlier. However, they were related to SU2 version 3.0. Has anyone been able to run this case using SU2 2.7 successfully?
2. Also would like to know whether SU2 2.7 would support NS simulation in rotating frame of reference? If yes what is the freestream Mach and Reynolds number to be provided (since this is a hover case freestream M = 0 and so is Re but SU2 won't accept these values). In an earlier post I read that periodic boundary conditions are not fully supported. Could someone please elaborate on this.
Thanks for your help,
Regards,
Deepanshu.
deeps is offline   Reply With Quote
Old   May 13, 2014, 02:39
Hennet_m is on a distinguished road
I have obtained the same problem using version 3.0 of SU2. Using hyperMesh, I have created a mesh without symetricals boundaries (I have modeled two blades) and It works very well!
Hope it helps,
Martin
Hennet_m is offline   Reply With Quote
Old   May 15, 2014, 15:26
Sean R. Copeland
copeland is on a distinguished road
Hello Deepanshu,
Unfortunately, the periodic boundary conditions in SU2 are a little out of date with the rest of the code and right now they don't function properly. Martin's solution of simulating the full geometry is the best solution to the problem if you're looking to get results immediately. We are actively correcting the issues with the periodic boundary conditions and we hope to have the problem resolved & support periodic boundary conditions again within a week or two. Stay tuned for updates!
-Sean
copeland is offline   Reply With Quote
Old   May 19, 2014, 00:40
Dear Sean and Martin,
Thank you for your suggestions. I'll try simulating the complete pair of blades and will let you know if there are any issues.
Regards,
Deepanshu.
Old   June 20, 2014, 06:29
Hello Martin,
Could you share your config file? Even after modeling 2 blades I'm not getting a converged solution.
Thanks,
Deepanshu.
Old   June 24, 2014, 20:53
Thomas D. Economon
economon is on a distinguished road
Please see the reply here about the new updated C & T case for SU2 V3.2... I think this should clear up some things:
http://www.cfd-online.com/Forums/su2...ade-model.html
T
economon is offline   Reply With Quote
Setup of a turbine stator blade conjugate heat transfer simulation mitra22 CFX 0 February 7, 2014 04:53
Errors running Caradonna (rotating blade) test case Gaso SU2 1 June 13, 2013 18:17
Fan Blade Simulation. 2D CFD with FLUENT? CFX? aerospain ANSYS 0 December 3, 2010 06:08
helicopter rotor blade simulation Cesare Ghermandi CFX 1 June 8, 2004 19:27
Procedure to run unsteady simulation? STN Main CFD Forum 2 February 16, 2002 04:37
