Home > Forums > SU2
Restarting an optimization cycle
Like Tree1Likes
  • 1 Post By copeland
Old   May 9, 2014, 12:36
Default Restarting an optimization cycle
Sreekanth
shsreekanth is on a distinguished road
If I stop an optimization cycle after i get some designs, say, after the third design DSN003, and want to change some parameter like scale , how do I make the solver to start from the last known solution.
I gave the restart_sol = yes, but the when SU2 runs, it deletes all the previous designs and starts a fresh cycle.
Also, I would like to know, when would the optimization cycle stop? Should I stop it after some particular number of iterations, or would SU2 stop by itself?
Regards,
Sreekanth
shsreekanth is offline   Reply With Quote
Old   May 15, 2014, 15:32
Sean R. Copeland
copeland is on a distinguished road
Hi Sreekanth,
When you launch a design in SU2, the python scripting creates subdirectories within your current working directory for each of the designs (DSN00X). If you want to restart the design process from a particular design, simply copy the restart file from the desired design directory (DSN00X) back to your top-level working directory and set RESTART_SOL to 'YES'. When you re-run the design script, it will delete the other directories unless you move them to another renamed directory.
Hope that helps, good luck
-Sean
shsreekanth likes this.
copeland is offline   Reply With Quote
Old   May 28, 2014, 04:44
Sreekanth
But what about the mesh file? How do I get the mesh file for the latest design. What I do now is to copy the actual mesh to the DESIGNS/DSN0XX/DECOMP/ directory, run "SU2_MDC config_MDC.cfg " and get a new file. Is this the right way?
Also, in one of the presentations it was mentioned that it is possible to export the final design as ".stl" file. How can I do this
Regards,
Sreekanth
Old   June 5, 2014, 14:56
Sean R. Copeland
Hi Sreekanth,
If you have the value of the design variables at the latest design iteration, you can always start from your baseline mesh and re-run the mesh deformation tools to re-generate the appropriate volumetric mesh from the last design iteration.
If you want an .stl file of the final design, just run SU2_MDC with the "VISUALIZE_DEFORMATION=YES" in the configuration file. You can do this without specifying any deformation of the surface as well if you already have a design you like.
-Sean
Old   June 5, 2014, 15:10
Trent Lukaczyk
rktchip is on a distinguished road
Sreekanth,
There should be a project file that stores the optimizer's progress, called "project.pkl" in the folder you called SU2. use the extra command line option that will read this file to restart --
shape_optimization.py ... -n project.pkl
for more info, check the help --
shape_optimization.py -h
- Trent
rktchip is offline   Reply With Quote
Thread Tools
Trackbacks are On
Airfoil Shape Optimization using gradient based methods jaiswal Main CFD Forum 1 April 10, 2014 11:22
Total force optimization or pressure force optimization? robyTKD SU2 Shape Design 1 August 19, 2013 15:54
COMSOL: optimization applied to a laminar flow tdh89 Main CFD Forum 0 April 30, 2012 08:57
simulation not completed in HPDC (thin wall casting) flyingming FLOW-3D 3 January 20, 2010 12:24
BOOK ON OPTIMIZATION OF FORTRAN CODES Alberto Main CFD Forum 3 November 10, 2008 07:07
