Home > Forums > Software User Forums > SU2
Reconstruction of variables
Like Tree1Likes
  • 1 Post By fpalacios
Old   May 17, 2014, 05:51
Default Reconstruction of variables
Sourabh Bhat
heySourabh is on a distinguished road
I have just started using SU2 and I am able to run it. Using SU2 seems very straight forward and easy.
I would like to use SU2 for higher resolution calculations by implementing WENO reconstruction. Can someone please direct me as to which classes (and .cpp file) need to be modified?
Explaining the method for finding the surrounding cells average variable values and dimension will be of great help. I am unable to locate the class (and source file) where variable reconstruction is done.
Thanks,
Sourabh
heySourabh is offline   Reply With Quote
Old   May 18, 2014, 21:26
Francisco Palacios
fpalacios is on a distinguished road
Originally Posted by heySourabh View Post
Thanks,
Sourabh
Hi Sourabh, thanks a lot for you interest in SU2.
All the geometrical preprocessing is done in
void Geometrical_Preprocessing(CGeometry ***geometry, CConfig **config, unsigned short val_nZone) { }
in definition_structure.cpp
At the very beginning of the subroutine SU2 computes the Elements surrounding Points (EsuP), Points surrounding Points (PsuP) and Elements surrounding Elements (EsuE). The control volume determination is done in
geometry[iZone][MESH_0]->SetControlVolume(config[iZone], ALLOCATE);
SU2 is an edge based solver that use the dual grid control volume.
I hope this help, and please let us posted with your progress, I high order reconstruction in SU2 would be very interesting for the open source community.
Cheers,
Francisco
heySourabh likes this.
fpalacios is offline   Reply With Quote
Old   May 18, 2014, 21:57
Sourabh Bhat
Thank you very much, that certainly helped.
Thanks,
Sourabh
reconstruction
Reconstruction of the parallel case with dynamic mesh makaveli_lcf OpenFOAM Post-Processing 7 October 18, 2023 11:28
$FOAM_USER_APPBIN & LIBBIN variables not set rassilon OpenFOAM Installation 2 February 16, 2010 20:54
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 15:45
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
Saving variables on a user patch with physical coordinates Zoltan Turzo CFX 2 April 20, 2000 15:05
