Home > Forums > Software User Forums > SU2
unsteady simulation using dynamic mesh+ rigid motion
Old   June 7, 2014, 00:37
Default unsteady simulation using dynamic mesh+ rigid motion
何建东
hejiandong is on a distinguished road
Hi.
i have done some simulation with this method, it is really good because there is no need to deform the grid. but the farfield boundary also picthing and plunging.
is it a strict unsteady algorithm? anyone can tell me the difference between this method and moving reference frame method in Fluent.
In addition, codes like fluent use dynamic mesh+UDF or sliding mesh to solve these problem.such as
https://www.youtube.com/watch?v=01hOD68DxrM
https://www.youtube.com/watch?v=kxFt3C7vYZY
hejiandong is offline   Reply With Quote
Old   June 24, 2014, 16:15
Thomas D. Economon
economon is on a distinguished road
Thanks for the post, and it's great to hear that you're interested in unsteady simulations on dynamic meshes in SU2. We have quite a few options for these types of simulations, including: steady flows with moving wall BCs, unsteady calculations with rigidly transforming meshes, and unsteady calculations with dynamically deforming meshes. For the dynamic mesh calculations, we can currently prescribe things such as pitching, plunging, and rotation.
At the moment, sliding mesh capabilities are not available, but these are only necessary for calculations that feature multiple surfaces in relative motion to one another. Otherwise, the options above should cover most applications of interest. You may find the notes here useful for trying these capabilities in SU2 (and there are some test cases now available as well): http://su2.stanford.edu/documents/SU...edAnalysis.pdf.
All the best,
Tom
economon is offline   Reply With Quote
Dynamic mesh simulation (pimpleDyMFoam) problem sidlof OpenFOAM Running, Solving & CFD 6 April 12, 2013 11:24
[Other] Dynamic Mesh Motion craptors OpenFOAM Meshing & Mesh Conversion 0 June 28, 2012 14:47
Use mesh motion to introduce angle for static simulation dancfd OpenFOAM Running, Solving & CFD 1 November 18, 2010 19:15
Turbulent problems during Dynamic Mesh Motion arturojortega FLUENT 2 June 2, 2009 10:33
Polynomial Dynamic Mesh Motion AVK Fluent UDF and Scheme Programming 1 March 27, 2009 09:51
