Home > Forums > Software User Forums > SU2
Question about parallel compute in windows 7
Old   May 28, 2014, 10:56
Default Question about parallel compute in windows 7
XingYu
454514566@qq.com is on a distinguished road
I want to Parallel compute a file in windows 64,the computer is installed :
MSMPISetup.exe
SU2-3.0.000-64-bit-Parallel.exe
python 2.7
numpy and scipy
When computing a file,I enter the "python parallel_computation.py -f
turb_ONERAM6.cfg -p 2 " in cmd.exe and face the error:
D:\>parallel_computation.py -f inv_NACA0012.cfg -p 2
the command: mpiexec -np 2 C:\SU2\SU2_DDC config_DDC.cfg
the location: D:\
WARNING: unrecognized option in the config. file: GRID_DEFORM_METHOD.
| _____ _ _ ___ |
| / ____| | | | | |__ \ Web: su2.stanford.edu |
| _____ _ _ ___ |
| | (___ | | | | ) | Twitter: @su2code |
| \___ \ | | | | / / Forum: www.cfd-online.com/Forums/su2/ |
| ____) | | |__| | / /_ |
| |_____/ \____/ |____| Suite (Domain Decomposition Code) |
| Release 2.0.10 |
| Release 2.0.10 |
| Stanford University Unstructured (SU2). |
| Copyright (C) 2012-2013 Aerospace Design Laboratory (ADL). |
| SU2 is distributed in the hope that it will be useful, |
| but WITHOUT ANY WARRANTY; without even the implied warranty of |
| MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU |
| Lesser General Public License (version 2.1) for more details. |
------------------------ Physical case definition -----------------------
Input mesh file name: mesh_NACA0012_inv.su2
-------------------------- Output information ---------------------------
Don't visualize the partitions.
------------------- Config file boundary information --------------------
Euler wall boundary marker(s): airfoil.
Far-field boundary marker(s): farfield.
---------------------- Read grid file information -----------------------
Two dimensional problem.
10216 interior elements.
10216 triangles.
5233 points.
2 surface markers.
200 boundary elements in index 0 (Marker = airfoil).
50 boundary elements in index 1 (Marker = farfield).
------------------------ Divide the numerical grid ----------------------
----------------------------- Write mesh files --------------------------
job aborted:
[ranks] message
[0] terminated
[1] process exited without calling finalize
---- error analysis -----
[1] on XingYu-PC
C:\SU2\SU2_DDC ended prematurely and may have crashed. exit code 0xc0000005
SU2 process was terminated by signal '3'
I look forward to your advice,thank you so much!
454514566@qq.com is offline   Reply With Quote
Old   June 5, 2014, 10:19
Michael Colonno
mcolonno is on a distinguished road
Please build & run one of the MS-MPI test programs to confirm that software is running properly on your system and report the output. From the output provided it seem like a core MPI issue.
mcolonno is offline   Reply With Quote
Old   June 5, 2014, 10:28
XingYu
Thank your reply,I want to sure if the MSMPI install is wrong:
MSMPI is installed in 'C:\Program Files\Microsoft MPI',and I set the PATH which is'C:\Program Files\Microsoft MPI\Bin',later,nothing is doing,Are there some questiones?
the error is similar to this http://www.cfd-online.com/Forums/su2...rror-help.html
Old   June 5, 2014, 11:05
XingYu
I try to run a software 'cpi.exe',there is a error,the DOc is showing:
C:\Windows\System32>D:
D:\>mpiexec -np 2 cpi.exe
Fatal protocol error: check version between Mpiexec.exe, Msmpi.dll, and Smpd.exe
And I can not find the 'Msmpi.dll' in MSMPI, something is wrong?
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
parallel computation in Windows sheila FLUENT 1 July 16, 2007 07:11
MPICH Parallel Run Error on the Windows Server2003 Saturn CFX 3 August 29, 2006 08:42
ANSYS CFX 10.0 Parallel Performance for Windows XP Saturn CFX 4 August 13, 2006 12:27
Windows 64-bit, Distributed Parallel Run Issues... Erich CFX 3 March 28, 2006 16:36
