Home > Forums > Software User Forums > SU2
TNE2_NAVIER_STOKES Error
Old   June 24, 2014, 09:56
Default TNE2_NAVIER_STOKES Error
Jeffrey van Oostrom
Doriris is on a distinguished road
I'm trying to run a TNE2 simulation for my test case, however, it is unable to do so. At the solver preprocessing, the terminal displays: "Area projection in the y-plane = 0.", after which SU2 eats all available memory, causing my machine to stutter and my Chrome to crash.
Any ideas?
Thanks,
Jeffrey
Doriris is offline   Reply With Quote
Old   June 24, 2014, 20:59
Sean R. Copeland
copeland is on a distinguished road
Hey Jeffrey,
It's likely a set of bad (or omitted) input parameters that's causing the crash. The TNE2 solver is still not quite at the level of development as the rest of the code, so unfortunately, events like these are common when running nonequilibrium calculations. I'll send you a configuration file that I use for my test cases and you can compare it with what you're running to see if there's anything going on.
Regards,
Sean
copeland is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
