Home > Forums > Software User Forums > SU2
please help with the following error
Old   July 2, 2014, 07:13
Default please help with the following error
Amit
Amit_Pawarpawar is on a distinguished road
i am a new user for SU2, a novice too.
i get the following error on running a .cfg file in parallel
Traceback (most recent call last):
File "/opt/SU2/bin/parallel_computation.py", line 111, in <module>
main()
File "/opt/SU2/bin/parallel_computation.py", line 56, in main
options.divide_grid )
File "/opt/SU2/bin/parallel_computation.py", line 71, in parallel_computation
config = SU2.io.Config(filename)
File "/opt/SU2/bin/SU2/io/config.py", line 91, in __init__
raise IOError , 'Could not find config file: %s' % filename
IOError: Could not find config file: channel.cfg
amit@amit-Z580:~/Desktop/chanl10*10$
this maybe a basic doubt,but still help me with it.
thanks in advance
Amit_Pawarpawar is offline   Reply With Quote
Old   July 2, 2014, 14:31
Brendan Tracey
btracey is on a distinguished road
What did you call from the command line? It looks like you aren't supplying a config file
btracey is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
