Home > Forums > Software User Forums > SU2
SU2 and Caeses Friendship Framework
Like Tree1Likes
  • 1 Post By Wenni
Old   June 18, 2014, 18:55
Default SU2 and Caeses Friendship Framework
Paul Keane
Sailplan is on a distinguished road
Hi there,
I have Caeses https://www.friendship-systems.com/products/caeses and SU2 working neatly on Windows 8 however I'm not clear how to get these two programs talking to each other.
There are some examples for using OpenFoam with Caeses on the Web but they are incomplete and lack detail.
Has anyone managed to get SU2 working with Friendship Framework using the Software Connection routines?
Thank you
Paul
Sailplan is offline   Reply With Quote
Old   June 24, 2014, 20:58
Thomas D. Economon
economon is on a distinguished road
Dear Paul,
We do not have any experience with coupling SU2 and Caeses. However, it does sound interesting, and if you manage to get the codes talking to each other, we would love to hear about it!
Cheers,
Tom
economon is offline   Reply With Quote
Old   June 25, 2014, 18:24
Default Set an exe using an input file
Paul Keane
Thanks Tom,
There is a routine described at the link below though I have not been able to make it work. Perhaps some of the forum users will understand what is being proposed?
http://www.friendship-systems.com/fo...an-input-file/
Kind regards
Paul
Old   September 19, 2014, 11:16
Default Su2 + caeses guide
Karsten Wenzke
Wenni is on a distinguished road
Hey Paul,
I have created a small tutorial for you.
I've posted it in the Users Forum of CAESES.
http://www.friendship-systems.com/fo...eses-coupling/
You can download it and try it. I hope this pdf and the project file solve you set up problem.
Cheers,
Karsten
fumiya likes this.
Wenni is offline   Reply With Quote
Old   September 22, 2014, 10:10
Default SU2 and CAESES
Claus Abt
Frameworker is on a distinguished road
HI Karsten,
How do we get values like lift and drag into the project?
Cheers
Claus
Frameworker is offline   Reply With Quote
Old   October 8, 2014, 16:29
Karsten Wenzke
Hey Claus,
that is farely easy.
You just have do this.
1. go to your SU2 Software Connector
2. add the history.plt file to the 'Result Values' Section (lower right side of the window)
3. double click history.plt
4. click on the green plus button next to 'Values'
5. set 'Line' to -1 (-1 makes sure to always pick the last line)
6. set 'Column' to 1 (first column represents CLift)
7. click once on the blue symbol in the 'Results Preview' Section
this creates a Paramter with the corresponding CLift Value in the CAD tab.
Repeat this for every result value you like to monitor.
If you have further questions don't hesitate to ask.
Cheers,
Karstem
Old   October 26, 2014, 14:11
Default Thanks, next steps
Paul Keane
Karsten,
That's fantastic. I have everything talking now and I've worked through several different tutorials.
As a Yacht Designer I found the Oneram Wing tutorial the most relevant simply because it deals with a 3d shape. After ensuring the tutorial worked I set about adapting it's mesh and config files.
In the mesh file I tried swapping the Oneram Wing for the underwater section of a yacht hull shape. The hull had been created in Blender and imported into enGrid. From enGrid I exported in Su2 format, so far so good.
I'm still working through the errors being thrown by the config file and at this time I've been unable to get it all working. I'm hitting hurdles about how the mesh is defined.
I'm not finished with it! I know that the time I'm spending working through the sections and variables in the config file and on meshing skills will be invaluable.
I may (probably!) be back onto the forum for some help if I don't make a breaktrough soon though when I do post again I want to be able to explain exactly what is happening and exactly what I'm trying to achieve.
I'm still on a learning curve here.
Regards
Paul
caeses, friendship framework, software connection
