August 27, 2014, 10:55 |
Accuracy problem
Dear all,
I am testing SU2 V3.0 for transonic flows, I found that using Roe scheme gives me a very big drag coefficient while the lift coefficient is ok, and computing with JST (default coefficients) gives a better result but it seems that the numerical dissipation is still so big that the shocks are badly predicted. And it is also the case for a high lift configuration computation. Does anybody knows why? Which scheme is the best candidate for this kind of application? Thank you for your help! |
August 28, 2014, 15:29 |
#2 | |
Francisco Palacios
Rep Power: 15 |
Dealing with Roe you typically need slope limiters (2ND_ORDER_LIMITER), Venkat is the best choice, but the selection of the coefficient (LIMITER_COEFF= 0.3) is cases dependent. Thanks for using SU2, Cheers, Francisco |
accuracy |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 10 | February 7, 2024 21:50 |
Problem with interFoam; Wave/wiggle alpha1 behavior | JonW | OpenFOAM | 10 | February 4, 2023 07:27 |
conduction problem | venkataramana | OpenFOAM | 3 | December 1, 2013 07:30 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 08:39 |
