October 28, 2014, 10:34 |
write unsteady issue
Hi everyone,
I am running a simulation where in config file I have : UNSTEADY_SIMULATION= TIME_STEPPING TIME_DISCRE_FLOW= RUNGE-KUTTA_EXPLICIT WRT_SOL_FREQ= 50 I would like to write distinct restart and the full volume solution files every WRT_SOL_FREQ steps (e.g. restart_flow_0050.dat, flow_0050.dat , restart_flow_0100.dat, flow_0100.dat and so on), but the code only writes one restart file and each time writing, it only overwrites that single file and doesn't create new files for every WRT_SOL_FREQ step. Is there a way to do this? PS. I think for dual time-stepping this is not an issue. Thanks |
October 29, 2014, 01:58 |
Vino
Rep Power: 13 |
It is not possible to get solutions at different time level using TIME_STEPPING. It overwrites the file at every time. finally you get only one solution file. you may have to modify the code to write different solution files at different time level. As you said, Dual time stepping gives solution files for each time.
[snappyHexMesh] Debug option in snappy / Write volScalarField with cellLevel for postprocessing | Ruli | OpenFOAM Meshing & Mesh Conversion | 1 | March 30, 2014 08:57 |
unsteady udf for concentration uds | borhan_sd@yahoo.com | Fluent UDF and Scheme Programming | 0 | July 15, 2013 03:32 |
Meshing related issue in Flow EFD | appu | FloEFD, FloWorks & FloTHERM | 1 | May 22, 2011 08:27 |
Unsteady Boundary Layer Problem | C.J.Yoon | Main CFD Forum | 0 | January 27, 2006 04:19 |
Under relaxation factor for unsteady NS scheme? | zonexo | Main CFD Forum | 0 | September 26, 2005 21:15 |
