Home > Forums > Software User Forums > SU2
Parallelizing SU2 in PBS
Old   July 29, 2019, 09:06
Post Parallelizing SU2 in PBS
Nadeem Kever
NKever is on a distinguished road
I am trying to run the shape_optimization.py script and use all my available nodes in PBS and I don't think I am doing this right.
Here is my script:
#PBS -q devel
##PBS -q long
##PBS -q normal
#PBS -W group_list=a1489
#PBS -lselect=50:ncpus=28:model=bro,walltime=02:00:00
##PBS -lselect=80:ncpus=28:model=bro,walltime=08:00:00
##PBS -lselect=80:ncpus=28:model=bro,walltime=50:00:00
#PBS -N test_su2
# Request that regular output and terminal output go to the same file
#PBS -j oe
#PBS -m n
# go to where the qsub was performed.
cd $PBS_O_WORKDIR
# Running Program
export SU2_RUN="/home6/nkever/su2/install/SU2/bin"
export SU2_HOME="/home6/nkever/su2/src/SU2"
export PATH=$PATH:$SU2_RUN
export PYTHONPATH=$PYTHONPATH:$SU2_RUN
module load mpi-sgi/mpt
module load python/2.7.15
module load comp-intel/2018.0.128
./shape_optimization.py -g CONTINUOUS_ADJOINT -o SLSQP -f inv_NACA0012_basic.cfg -n 400
echo "finished mpirun"
So I think the issue may be the -n, my interpretation is that the number of partitions tells su2 the amount of nodes. How do I use all my nodes?
I've seen this thread already, but I'm not sure it addresses my question. Thank you!
NKever is offline   Reply With Quote
Old   August 8, 2019, 15:39
Jayant Mukhopadhaya
jayantmukho is on a distinguished road
Hey Nadeem,
Is your issue that PBS doesn't use the different nodes and just tries to start all 400 processes on 1 node?
I had this particular issue when I was trying to run using openmpi with PBS. In that case, the openmpi installation that I was using wasn't configured to work with torque/pbs (https://www.open-mpi.org/faq/?category=tm). It required a particular option to be set when configuring openmpi.
I haven't used SGI MPT before so I am not certain if there is a similar issue that would need to be rectified.
jayantmukho is offline   Reply With Quote
Old   August 25, 2019, 04:42
pcg
Pedro Gomes
pcg is on a distinguished road
Hi Nadeem,
The problem might be that all nodes are executing the shape optimization script, and only one should since it is not an mpi-ready program (I think).
The simplest way to do this kind of thing would be to wrap the SU2 execution in a script that submits an individual job per SU2 run and waits for results.
Cheers,
Pedro
pcg is offline   Reply With Quote
pbs, su2
Problem running SU2 using PBS jzhen SU2 11 July 25, 2019 13:10
Introducing SU2 International Developers Society (IDS) fpalacios SU2 News & Announcements 1 June 17, 2019 22:38
Running SU2 Pyhton Script in Parallel with PBS Torque andromeda91 SU2 1 October 20, 2014 14:25
parallel computation with PBS error tsevine SU2 4 July 4, 2014 06:21
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 13:43
