August 5, 2015, 06:20 |
CGNS Output
Dear Developers,
I tried running the rans/naca turbulent case and used CGNS as the output format. I couldn't seem to find a .cgns output file at the end of the run. I set the solver to run for 10 steps with an output frequency of 5. Is there something I need to fix in the input or the SU2 source files ? SU2 version is 4 Thanks Dominic |
August 6, 2015, 03:27 |
Fixed it. If anyone needs to know how to do it, I'll post it here. It required me to do some modifications to the source.
August 7, 2015, 10:00 |
#3 | |
Heather Kline
github link: https://github.com/su2code/su2 |
August 30, 2019, 02:41 |
#4 | |
Haoge Li
I've been trying to export .cgns mesh with SU2, and it did using SU2_MSH or SU2_DEF. But there's something wrong with the CGNS mesh, it‘s not a binary file, and can't be imported to Pointwise or ICEM. So, I'm really interested in how you did with the CGNS output. Could you describe it in detail? I used the SU2 V6.2.0. Thank you so much! Sincerely, Haoge Li |
[swak4Foam] outputTime in Swak function | immortality | OpenFOAM Community Contributions | 20 | October 6, 2022 12:08 |
writing execFlowFunctionObjects | immortality | OpenFOAM Post-Processing | 30 | September 15, 2013 06:16 |
SU2_SOL compilation error and no cgns surface solution in output | Akash C | SU2 Installation | 1 | August 19, 2013 15:19 |
CGNS Output file parameters | ant0wn | SU2 | 1 | August 19, 2013 14:47 |
[ICEM] CGNS output problem | Pat84 | ANSYS Meshing & Geometry | 11 | May 1, 2013 20:56 |
