April 14, 2016, 12:21 |
Forcing the creation of solution files
Oliver V
Rep Power: 10 |
I'm running SU2 4.1.0 in parallel and I wonder if there's a way to generate solution files for 2 cases: 1. The solver reaches the maximum number of iterations without convergence. 2. The calculation overall has reached a prescribed walltime. The thing is, whenever the calculation doesn't converge in the allocated max iterations the solver only creates a restart file... which I can't directly open in paraview (or is there a restart_flow_to_vtk tool?). Whenever the calculation goes beyond the walltime, SU2 is terminated by the cluster mods. Thanks, Oliver |
April 14, 2016, 16:08 |
Tim Albring
Rep Power: 10 |
Hi Oliver,
if you run SU2_CFD in parallel there will always be just a restart file. You have to use SU2_SOL to create the flow.dat or flow.vtk which you can then open with Tecplot/Paraview. Tim |
April 14, 2016, 16:40 |
Oliver V
Rep Power: 10 |
Thanks!
I always use 'python parallel_computation.py -f cfgfile -n nprocs' so I never really used the "vtk generator" since it's done automatically. So this means I can actually erase the solutions and just keep the restart files? nice! I'll have to learn how to use the SU2_SOL tool, but I think it's exactly what I was looking for. Thanks again. Oliver |
April 15, 2016, 04:13 |
Tim Albring
Rep Power: 10 |
Hi Oliver,
if you haven't changed the default file names you have to copy restart_flow.dat to solution_flow.dat first. Then just run SU2_SOL. Tim |
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 21:22 |
Exact solution of Burgers equation | mcaro | Main CFD Forum | 3 | January 25, 2011 06:46 |
Does FOAM converge to exact solution in Laplace equation? | santiagomarquezd | OpenFOAM Running, Solving & CFD | 0 | March 26, 2010 07:52 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 10:46 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
