August 15, 2016, 05:59 |
kowalski
Rep Power: 9 |
Hi all,
even if SU2 is compiled with parallel support (see configuration summary below). When I try: mpirun -n 8 SU2_CFD config.cfg I get 8 serial independent jobs instead of an actual parallel job. Is there anything I am missing? Thanks Marco Here's the output of the configuration script: checking build system type... x86_64-unknown-linux-gnu checking host system type... x86_64-unknown-linux-gnu checking target system type... x86_64-unknown-linux-gnu checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... /bin/mkdir -p checking for gawk... gawk checking whether make sets $(MAKE)... yes checking whether make supports nested variables... yes checking for style of include used by make... GNU checking whether the C++ compiler works... yes checking for C++ compiler default output file name... a.out checking for suffix of executables... checking whether we are cross compiling... no checking for suffix of object files... o checking whether we are using the GNU C++ compiler... yes checking whether /usr/bin/mpicxx accepts -g... yes checking dependency style of /usr/bin/mpicxx... gcc3 checking whether we are using the GNU C compiler... yes checking whether /usr/bin/mpicc accepts -g... yes checking for /usr/bin/mpicc option to accept ISO C89... none needed checking dependency style of /usr/bin/mpicc... gcc3 checking whether /usr/bin/mpicc and cc understand -c and -o together... yes checking for ranlib... ranlib checking whether we are using the GNU C++ compiler... (cached) yes checking whether /usr/bin/mpicxx accepts -g... (cached) yes checking dependency style of /usr/bin/mpicxx... (cached) gcc3 checking how to run the C preprocessor... /usr/bin/mpicc -E checking for grep that handles long lines and -e... /bin/grep checking for egrep... /bin/grep -E checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking size of short int... 2 checking size of int... 4 checking size of unsigned int... 4 checking size of long int... 8 checking size of float... 4 checking size of double... 8 checking size of void *... 8 checking X11/Intrinsic.h usability... no checking X11/Intrinsic.h presence... no checking for X11/Intrinsic.h... no <<< Configuring library with Metis support >>> <<< Configuring library with Parmetis support >>> checking for /usr/local/lib/libcgns.a... yes checking for /usr/local/include/cgnslib.h... yes checking that generated files are newer than configure... done configure: creating ./config.status config.status: creating externals/tecio/Makefile config.status: creating externals/metis/Makefile config.status: creating externals/parmetis/Makefile config.status: creating Makefile config.status: creating externals/Makefile config.status: creating Common/lib/Makefile config.status: creating SU2_CFD/obj/Makefile config.status: creating SU2_DOT/obj/Makefile config.status: creating SU2_MSH/obj/Makefile config.status: creating SU2_DEF/obj/Makefile config.status: creating SU2_SOL/obj/Makefile config.status: creating SU2_GEO/obj/Makefile config.status: creating SU2_PY/Makefile config.status: executing depfiles commands ------------------------------------------------------------------------- | ___ _ _ ___ | | / __| | | |_ ) Release 4.2.0 'Cardinal' | | \__ \ |_| |/ / | | |___/\___//___| Suite | | | ------------------------------------------------------------------------- | SU2 Lead Dev.: Dr. Francisco Palacios, Francisco.D.Palacios@boeing.com| | Dr. Thomas D. Economon, economon@stanford.edu | ------------------------------------------------------------------------- | SU2 Developers: | | - Prof. Juan J. Alonso's group at Stanford University. | | - Prof. Piero Colonna's group at Delft University of Technology. | | - Prof. Nicolas R. Gauger's group at Kaiserslautern U. of Technology. | | - Prof. Alberto Guardone's group at Polytechnic University of Milan. | | - Prof. Rafael Palacios' group at Imperial College London. | ------------------------------------------------------------------------- | Copyright (C) 2012-2016 SU2, the open-source CFD code. | | | | SU2 is free software; you can redistribute it and/or | | modify it under the terms of the GNU Lesser General Public | | License as published by the Free Software Foundation; either | | version 2.1 of the License, or (at your option) any later version. | | | | SU2 is distributed in the hope that it will be useful, | | but WITHOUT ANY WARRANTY; without even the implied warranty of | | MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU | | Lesser General Public License for more details. | | | | You should have received a copy of the GNU Lesser General Public | | License along with SU2. If not, see <http://www.gnu.org/licenses/>. | ------------------------------------------------------------------------- Build Configuration Summary: Source code location: /home/marco/Useless/solver-su2/SU2 Install location: /home/marco/Useless/solver-su2 Version: 4.2.0 C++ Compiler: /usr/bin/mpicxx C Compiler: /usr/bin/mpicc Preprocessor flags: -DHAVE_MPI Compiler flags: -O3 Linker flags: MPI support: yes Metis support: yes Parmetis support: yes TecIO support: no CGNS support: yes HDF5 support: no SZIP support: no ZLIB support: no Mutation++ support: no Jsoncpp support: no LAPACK support: no Datatype support: double yes complex no codi_reverse no codi_forward no External includes: -DHAVE_PARMETIS -I$(top_srcdir)/externals/parmetis/include -DHAVE_METIS -I$(top_srcdir)/externals/metis/include External libs: $(top_builddir)/externals/parmetis/libparmetis.a $(top_builddir)/externals/metis/libmetis.a Build SU2_CFD: yes Build SU2_DOT: yes Build SU2_MSH: yes Build SU2_DEF: yes Build SU2_SOL: yes Build SU2_GEO: yes Please be sure to add the $SU2_HOME and $SU2_RUN environment variables, and update your $PATH (and $PYTHONPATH if applicable) with $SU2_RUN. |
August 15, 2016, 06:24 |
Rep Power: 13 |
Hi Marco,
try this: parallel_computation.py -f config.cfg -n 8 Cheers, Alberto |
August 15, 2016, 06:29 |
kowalski
Rep Power: 9 |
Thanks Alberto, but still no dice...same behaviour as before
I am checking the log of the make and the make install, but as of now I cannot see anything major. Cheers Marco |
August 15, 2016, 06:38 |
Rep Power: 13 |
Stupid question: you say that they are running in serial because they are all running on the same core (and when you kill one process the other ones are not killed as well)?
August 15, 2016, 06:50 |
kowalski
Rep Power: 9 |
What I see is that I get printed the same exact line 8 times, i.e.
101217 triangles. 66956 quadrilaterals. 101217 triangles. 66956 quadrilaterals. 101217 triangles. 66956 quadrilaterals. 101217 triangles. 66956 quadrilaterals. 101217 triangles. 66956 quadrilaterals. 101217 triangles. 66956 quadrilaterals. 101217 triangles. 66956 quadrilaterals. 101217 triangles. 66956 quadrilaterals. ------------------------- Geometry Preprocessing ------------------------ Setting point connectivity. ------------------------- Geometry Preprocessing ------------------------ Setting point connectivity. ------------------------- Geometry Preprocessing ------------------------ Setting point connectivity. ------------------------- Geometry Preprocessing ------------------------ Setting point connectivity. ------------------------- Geometry Preprocessing ------------------------ Setting point connectivity. ------------------------- Geometry Preprocessing ------------------------ Setting point connectivity. ------------------------- Geometry Preprocessing ------------------------ Setting point connectivity. ------------------------- Geometry Preprocessing ------------------------ Setting point connectivity. Renumbering points (Reverse Cuthill McKee Ordering). Renumbering points (Reverse Cuthill McKee Ordering). Renumbering points (Reverse Cuthill McKee Ordering). Renumbering points (Reverse Cuthill McKee Ordering). Recomputing point connectivity. Renumbering points (Reverse Cuthill McKee Ordering). Renumbering points (Reverse Cuthill McKee Ordering). Renumbering points (Reverse Cuthill McKee Ordering). Renumbering points (Reverse Cuthill McKee Ordering). Recomputing point connectivity. Recomputing point connectivity. Recomputing point connectivity. Recomputing point connectivity. Recomputing point connectivity. Recomputing point connectivity. I believe that this is the typical output of a code which is not running properly in parallel. Other posts indicate that this is due to an incorrect configuration (with no metis/parmetis), which I do not have ( see original post) and I get no error / warning while compiling, except for this warning: ar: `u' modifier ignored since `D' is the default (see `U') which seems related to a way of updating the libraries. But since I have removed everything and made a clean installation from scratch, this might not be relevant for my case. Thanks Marco |
August 18, 2016, 12:08 |
Tim Albring
Rep Power: 10 |
August 18, 2016, 12:14 |
kowalski
Rep Power: 9 |
Hi Tim,
this was my first thought, but unless the printout I get from the configure script and make install (see my previous posts) is faulty, I am compiling with METIS. PARMETIS and the mpicc and mpicxx, which to the best of my knowledge is saying I am doing things in parallel. Any other suggestion would be welcome. Marco |
August 18, 2016, 13:08 |
#8 | |
Heather Kline
Rep Power: 13 |
August 23, 2016, 17:12 |
#9 |
Giulio
Rep Power: 12 |
It could also be related to which mpi implementation you are using on your machine.
Do you have openmpi or mpich? if you have both of them you may have to specify the right one (which is the one you used to compile SU2) in order to run SU2 on multiple cores. Try using either "mpirun.openmpi" or "mpirun.mpich"
Giulio Gori Phd candidate, Politecnico di Milano |
August 25, 2016, 17:56 |
#10 |
Zach Davis
Rep Power: 16 |
I would have to agree with LaSerpe. This behavior suggests that the mpirun that your shell environment is pointing to is not from the same MPI installation that was used to compile SU2.
January 21, 2023, 06:49 |
#11 |
Philip Agenmonmen
Rep Power: 3 |
Were you able to solve this problem? Best Regards Philip |
January 21, 2023, 09:03 |
#12 |
bigfoot
Rep Power: 17 |
if you run SU2 in parallel on N cores, and you see SU2 output messages being repeated N times, then your mpi is not set up correctly. Make sure that you have mpi installed correctly, then make sure that you are using SU2 with the correct compilation option to be able to use mpi. Please read the installation carefully:
https://su2code.github.io/docs_v7/Installation/ And if you still have problems, please open a new issue and give us the details of your setup (windows/linux, mpich or openmp, etc...). |
metis, parallel job, parmetis |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
SU2 in parallel | suman91 | SU2 | 4 | September 26, 2014 20:38 |
SU2 parallel installation error | JAlbert | SU2 Installation | 2 | November 19, 2013 02:43 |
Parallel interfom trouble in execution | mer | OpenFOAM Running, Solving & CFD | 6 | October 18, 2005 05:45 |
