May 30, 2013, 10:08 |
1D solution of shock tube
Ehsan
Rep Power: 26 |
Hi
shock tube is a basic CFD problem for testing systems with discontinuities. its valuable that provide a analytic program for 1D inviscid shock tube that gives flow properties at each sections whenever the user wants,in any form like a Matlab program or what form that anyone interested thinks its good is worthy.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
June 18, 2013, 06:24 |
reducing CFL no.
Kaushik Roy
I have run the shock tube problem for various schemes and I found that when the CFL number is reduced, the error increases...can you explain why??
BTW the analytical solution of shock tube is attached here |
June 18, 2013, 06:36 |
Ehsan
Rep Power: 26 |
thats a valuable work.could you add some explanations in different parts?
you compare error with what?
June 18, 2013, 06:45 |
Kaushik Roy
I have found the error in pressure and density by evaluating the diiference between the numerical solution and the exact solution and I have carried out the process for two values of CFL no, 0.5 and 0.1. The errors associated with CFL 0.1 are larger than CFL 0.5 and I would like to know why....
June 18, 2013, 06:57 |
Ehsan
Rep Power: 26 |
why this error occurs?
ehsan@Ehsan-com:~/Desktop$ gcc analytical_WR.c -o WR analytical_WR.c:4:18: fatal error: conio.h: No such file or directory compilation terminated.
June 27, 2013, 09:01 |
ShockTube program execution error
Ehsan
Rep Power: 26 |
what does errors mean?and how to resolve?
can anyone help?
June 27, 2013, 09:47 |
Daniel P. Combest
Added the stdlib.h header and compiled it correctly with
gcc -o output ShockTube.CPP -lm Code:
./output |
June 27, 2013, 11:25 |
Ehsan
Rep Power: 26 |
Thanks and whats the problem with this file?could you have a look into it?
June 27, 2013, 12:25 |
#9 |
Daniel P. Combest
Did you try to Google the error?
gcc -o output shockTube2.CPP -lm shockTube2.CPP:4:18: fatal error: conio.h: No such file or directory compilation terminated. |
Error with rhoCentralFoam in Shock tube | himanshu28 | OpenFOAM | 16 | February 23, 2018 00:20 |
Two solutions of Sod's shock tube problem | orxan.shibli | Main CFD Forum | 14 | May 20, 2016 21:41 |
Shock tube post #1000 | Belgio | ANSYS Meshing & Geometry | 2 | November 2, 2009 18:51 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Shock tube problem | AB | Siemens | 1 | November 9, 2004 00:25 |
