January 15, 2013, 08:33 |
contours fluent ----->> tecplot
amine
Rep Power: 13 |
Hello CFD Friends
could you tell me please how to export contours of temperature for example from fluent to tecplot , and from matlab to tecplot . I want to print the two contours on the same figure in order to compare results of fluent with results of matlab have a nice day Friends Thank you so much . |
January 16, 2013, 11:21 |
Scott Rumage
Rep Power: 16 |
One can load Fluent data into Tecplot 360 via the Fluent data loader, and in a separate frame one could load the Matlab data into Tecplot 360 via this mat2tecplot program described here: http://www.cfd-online.com/Forums/tecplot/103860-mat2tecplot.html
Once the two frames are in Tecplot and contoured to the same scale, one could then make one of the frames have a transparent background and then put the transparent frame on top of the other contour diagram. This might provide the comparison you are seeking. |
January 31, 2013, 14:35 |
amine
Rep Power: 13 |
Thank you Scott_rumage so much
January 31, 2013, 18:49 |
amine
Rep Power: 13 |
Hello again Scott_rumage
i didnt know how to do that?!!!could u describe me the different steps to that plz???i just downloaded the matlab code but it seems to not work thanx a lot |
Contours of density gradient in fluent 5? | Ricky Wong | FLUENT | 3 | May 19, 2015 01:39 |
Contours of turbulent kinetic energy in LES using ANSYS FLUENT 13 | khosrow | FLUENT | 5 | July 29, 2013 05:28 |
how can i export pathline from FLUENT to tecplot? | kerend | Tecplot | 0 | October 17, 2012 10:44 |
Fluent manually contours Range selection | Qazi Tanveer | FLUENT | 0 | July 6, 2012 03:23 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 13:43 |
