-   Tecplot (http://www.cfd-online.com/Forums/tecplot/)
-   -   Tecplot & decomposed domain (http://www.cfd-online.com/Forums/tecplot/112994-tecplot-decomposed-domain.html)
Zato_Ichi February 9, 2013 09:48
Dear all, i'm stuck in a problem with using Tecplot for data obtained in parallel computations. I use domain decomposition method for highly accurate hydrodynamics simulations. To avoid alot of reduce operations each process save binary data in it's own .dat file. There is Fortran subroutine which i use for saving:
SUBROUTINE SAVEBIN4(num)
USE Geometry1
USE ThermoAndFront2
USE Viscosity3
USE Parallel4
IMPLICIT REAL*8 (A-H,O-Z)
!INCLUDE 'C1.IN'
!INCLUDE 'C2.IN'
!INCLUDE 'C3.IN'
!INCLUDE 'C4.IN'
COMMON/IOF/IXYSZ,IXZSY,IYZSX
!CHARACTER(LEN=100) filename
INTEGER num
INTEGER CONVERTSTR3
INTEGER*4 s,i,istr(40),i1,i2
CHARACTER*20 cstr
REAL*4 r,r1(6)
!INTEGER 105+MRANK
!105+MRANK = 105+MRANK+MRANK
IUNIT = 205
OPEN(UNIT=IUNIT, FILE=FileName, STATUS='REPLACE', FORM='BINARY')
!Header identification
WRITE(205)'#!TDV75 '
!Integer order
i=1
WRITE(205)i
!Title
cstr='Flame test\0'C
n=CONVERTSTR3(istr,cstr)
WRITE(205)(istr(i),i=1,n)
!Number of variables
i=11
WRITE(205)i
!Variable names
cstr='X'C
WRITE(205)(istr(i),i=1,CONVERTSTR3(istr,cstr))
cstr='Y'C
cstr='Z'C
cstr='P'C
cstr='T'C
cstr='Rho'C
cstr='U'C
cstr='V'C
cstr='W'C
cstr='H2/AN'C
cstr='Vsound'C
!Zone description
!Zone marker
r=299.0
WRITE(205)r
!Zone name
WRITE(cstr,'(4HZone,I6.6,A)')num,CHAR(0)
!cstr=cstr//'\0'C
!Zone format
i=1
WRITE(205)i
!Zone color
i=-1
WRITE(205)i
!IMAX, JMAX, KMAX
!i=NZSm
!i1=NYSm
!i2=NXSm-NX1m-NX0m+1
i=NZSm
i1=NYSm-NY1m-NY0m+1
i2=NXSm-NX1m-NX0m+1
WRITE(205)i,i1,i2
!Data section marker
r=357.0
WRITE(205)r
!Data section
!Zone iplementation
r=299.0
WRITE(205)r
!Repeat vars
i=0
WRITE(205)i
!Var types
i=1
i1=1
i2=1
WRITE(205)i,i1,i2
i1=1
i2=1
i=1
WRITE(205)i1,i2,i
i1=1
i2=1
i=1
WRITE(205)i1,i2,i
i1=1
i2=1
WRITE(205)i1,i2
!Data
IJK=1+KL2+(NX0m-1)*NKX+(NY0m-1)*NKY;
IJS=IJK;IYS=1;IXS=1
DO 997 I=NX0m,NXSm-NX1m
DO 996 J=NY0m,NYSm-NY1m
DO 990 K=1,NZSm
!Saving data:
r1(1)=X(IJK+1)
r1(2)=X(IJK+2)
r1(3)=X(IJK+3)    !X(IJK+9)
r1(4)=X(IJK+8)    !X(IJK+10)
r1(5)=X(IJK+18)    !X(IJK+11)
r1(6)=X(IJK+7)    !X(IJK+8)
WRITE(IUNIT)r1(1),r1(2),r1(3),r1(4),r1(5),r1(6) !
r1(1)=X(IJK+9)
r1(2)=X(IJK+10)
r1(3)=X(IJK+11)
r1(4)=X(IJK+27)/X(IJK+4)
r1(5)=X(IJK+48)
!r1(3)=X(IJK+18)
IJK=IJK+KL
  990 CONTINUE
IJK=IJS+IYS*NKY
  996 IYS=IYS+1
IJS=IJS+NKX
IJK=IJS
IYS=1
  997 CONTINUE
CLOSE(IUNIT)
200 FORMAT(6E13.6)
201 FORMAT(4I7)
END
My domain structure is quite simple - it's a brick. So each .dat file has it's own header and data. Obviously, than i load this in tecplot, i get separated smaller bricks:
http://i46.tinypic.com/2vxf8dk.jpg
I've tried to make only one header on Rank 0 process, and other processes just save their data in that header file in some order. Best i've got:
http://i45.tinypic.com/2mm9ykk.jpg
Anyone have any ideas, how to make one solid zone from this clustered data ?
Many thanks for your help !
