April 26, 2018, 06:46 |
Tecplot slice command
Bereket Tsegai Habte
Hello guys, I am trying to use the slice command in Tecplot to remove an octant of a cubic microstructure and to visualise the remaining similar to the image attached.
Thanks |
April 30, 2018, 12:17 |
John Connell
Rep Power: 8 |
Hello bereket,
The slice commands will not cut out an octant of your data like you have shown. However, this can be done with the Data Alter menu and Value Blanking. Because the octant is known, you can create a Blanking variable like so: {Blank} = IF(X<=0 && Y<=0.5 && Z >= 0.25, 1, 0) Then if you navigate to the Value Blanking dialog and turn it on for Blank equal to 1, it will blank the region X less than 0, Y less than 0.5, Z greater than 0.25. Thanks, John Connell Tecplot Technical Support |
slices |
Display Modes | |
Command line program tec360 missing in Tecplot 360 EX | praveen | Tecplot | 2 | February 1, 2015 00:04 |
[DesignModeler] Slice command does not preserve bodies | jtipton2 | ANSYS Meshing & Geometry | 1 | July 31, 2013 12:48 |
tecplot 1D slice | user0314 | Tecplot | 0 | June 23, 2011 12:45 |
Bounded slice in Tecplot possible? | Sam | Tecplot | 1 | August 20, 2008 13:18 |
Tecplot Slice | Alex | Tecplot | 2 | April 28, 2006 09:28 |
