-   Tecplot (http://www.cfd-online.com/Forums/tecplot/)
-   -   Split zone in zones (http://www.cfd-online.com/Forums/tecplot/117330-split-zone-zones.html)
agustinvo May 6, 2013 17:04
Split zone in zones
I have this trouble: I export from Fluent a Tecplot Data file which contains cross-section areas of a duct. The problem is that I've defined the group of sections as an only one zone. Does it exist any form to separate these sections in Tecplot, or I should create these surfaces in Fluent? I can't use iso-surfaces, neither slices. I attach the file and an image.
https://docs.google.com/file/d/0B2XU...it?usp=sharing
afzaal August 14, 2016 02:11
Dear,
Have you found any solution to your problem? Recently i am also facing similar issue and i dont know how to divide a zone into sub zones in tecplot. If you have any solution, please guide me.
Thanks
