-   Tecplot (https://www.cfd-online.com/Forums/tecplot/)
-   -   Normalization of data in Tecplot (https://www.cfd-online.com/Forums/tecplot/120334-normalization-data-tecplot.html)
saeedi July 4, 2013 12:32
Hi there,
I need guidance on how to normalize the data in Tecplot.
I want to normalize the data (say in a 2-D plane) by the maximum value in the same plane. If I can do it in Tecplot which already has all the data, I do not need to re-run the post-processing and that will save a lot of time when the number of planes is high or etc.
An other problem for example:
In on pressure contour plot, I normalized the contours by (ro*Uinf^2). Now if I want to normalize by (0.5*ro*Uinf^2), I just need to divide the whole plane by 0.5 instead of running my original code.
I'd appreciate your comments and guidance.
scott_rumage July 12, 2013 18:24
Normalization of data in Tecplot - specify equations
I believe you would want to use the calculate variables option in Tecplot. From the Menu go to Data>>Alter>>Specify Equations, and then type something like:
{new normalized variable}= 0.5*ro*Uinf**2
See the Tecplot 360 user's manual (http://www.tecplot.com/support/documentation/ ) page 305 for details on proper syntax, etc. You can also click on "Help>>Tecplot 360 Help" in Tecplot 360, and search on "specify equations" to get examples of syntax and options.
Scott
saeedi July 12, 2013 22:44
Thanks very much Scott.
