Home > Forums > Visualization & Post-Processing Software > Tecplot
Creating Binary file using tecio.a
Old   June 30, 2012, 23:28
Default Creating Binary file using tecio.a
Juan Diego Colmenares
juaneco2710 is on a distinguished road
I'm new using Linux (Ubuntu 12.04 LTS, 64-bit). I am also new at using Tecplot360. I am trying to learn how to create binary files for Tecplot by reviewing the example files. I wonder if anyone knows how to solve it.
I've been trying to compile the example file simtest.f90, using these two commands:
1. gfortran -fcray-pointer -lstdc++ simtest.f90 tecio64.a
2. gfortran -fcray-pointer simtest.f90 tecio.f90
In the first case, I get a huge list of errors like this:
./util/tecio64.a(tecxxx.o): In function `__gnu_cxx::new_allocator<long>::deallocate(long*, unsigned long)':
tecxxx.cpp.text._ZN9__gnu_cxx13new_allocatorIlE1 0deallocateEPlm[__gnu_cxx::new_allocator<long>::deallocate(long*, unsigned long)]+0x19): undefined reference to `operator delete(void*)'
In the second case, I get that tecio.f90 unexpectedly ended.
If anyone can help me, I would appreciate it.
juaneco2710 is offline   Reply With Quote
Old   July 10, 2012, 17:57
D L
DLuo is on a distinguished road
What are the contents of simtest.f90?
If you have an ascii solution already in tecplot format, you can use a utility that Tec360 provides called preplot
[user@host dir]$ preplot [ascii_file.dat]
Hope that helps.
DLuo is offline   Reply With Quote
Old   August 17, 2012, 10:14
blackmask will become famous soon enough
It is not a good idea to create tecplot binary files directly because of its OS-, arch-, and version- dependency. Use PLOT3D format or other tecplot-compatible formats instead.
blackmask is offline   Reply With Quote
Old   July 22, 2013, 14:07
Default compiling Fortran source code using gfortran on Linux
Straton Spyropoulos
straton is on a distinguished road
Hello juaneco2710, we just posted a new KB article on compiling Fortran source code using gfortran on Linux:
http://www.tecplot.com/knowledgebase...tran-on-linux/
I hope this helps.
Straton, Tecplot technical support
support@tecplot.com
straton is offline   Reply With Quote
binary file, linux64, tecplot, ubuntu
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 13:14
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
