December 15, 2013, 02:30 |
Some problem of "Qcriterion.mcr&
yu. yuxuan
Rep Power: 12 |
I load the fluent "*.cas and *.dat" and then play the macro in http://download.tecplot.com/macros/Qcriterion.mcr
But it shows "enter the variable number" What the variable number means? is it the nodes number of my own structure or the range of the x axis or the number of points need to paint. I don't know. So I ask for help. |
December 16, 2013, 11:33 |
Scott Rumage
Rep Power: 16 |
I believe the macro is looking to confirm (and match-up) the name of the variable of velocity in the x direction (typically labeled U). The macro will also go on to ask for the name of the variable in the y & z direction (typically labeled V & W).
December 18, 2013, 06:22 |
#3 | |
yu. yuxuan
Rep Power: 12 |
I do the following to type But it gives the error. I give the code Code:
#!MC 1400 # Created by Tecplot 360 build 14.0.2.35002 $!ALTERDATA EQUATION = '{Q} = 0' $!VarSet |NUMVARSINIT| = |NUMVARS| $!VarSet |NUMVARSINIT| += 1 $!PROMPTFORTEXTSTRING |U| INSTRUCTIONS = "Enter the variable number for U" $!PROMPTFORTEXTSTRING |V| INSTRUCTIONS = "Enter the variable number for V" $!PROMPTFORTEXTSTRING |W| INSTRUCTIONS = "Enter the variable number for W" $!GLOBALTHREEDVECTOR UVAR = |U| $!GLOBALTHREEDVECTOR VVAR = |V| $!GLOBALTHREEDVECTOR WVAR = |W| $!ALTERDATA EQUATION = '{dudx} = ddx(u)' $!ALTERDATA EQUATION = '{dvdx} = ddx(v)' $!ALTERDATA EQUATION = '{dwdx} = ddx(w)' $!ALTERDATA EQUATION = '{dudy} = ddy(u)' $!ALTERDATA EQUATION = '{dvdy} = ddy(v)' $!ALTERDATA EQUATION = '{dwdy} = ddy(w)' $!ALTERDATA EQUATION = '{dudz} = ddz(u)' $!ALTERDATA EQUATION = '{dvdz} = ddz(v)' $!ALTERDATA EQUATION = '{dwdz} = ddz(w)' $!ALTERDATA EQUATION = '{s11} = {dudx}' $!ALTERDATA EQUATION = '{s12} = 0.5*({dudy}+{dvdx})' $!ALTERDATA EQUATION = '{s13} = 0.5*({dudz}+{dwdx})' $!ALTERDATA EQUATION = '{s22} = {dvdy}' $!ALTERDATA EQUATION = '{s23} = 0.5*({dvdz}+{dwdy})' $!ALTERDATA EQUATION = '{s33} = {dwdz}' $!ALTERDATA EQUATION = '{Omga12} = 0.5*({dudy}-{dvdx})' $!ALTERDATA EQUATION = '{Omga13} = 0.5*({dudz}-{dwdx})' $!ALTERDATA EQUATION = '{Omga23} = 0.5*({dvdz}-{dwdy})' $!ALTERDATA EQUATION = '{s2o2_11} = {s11}**2 + {s12}**2 + {s13}**2 - {Omga12}**2 - {Omga13}**2' $!ALTERDATA EQUATION = '{s2o2_12} = {s11}*{s12} + {s12}*{s22} + {s13}*{s23} - {Omga13}*{Omga23}' $!ALTERDATA EQUATION = '{s2o2_13} = {s11}*{s13} + {s12}*{s23} + {s13}*{s33} - {Omga12}*{Omga23}' $!ALTERDATA EQUATION = '{s2o2_22} = {s12}**2 + {s22}**2 + {s23}**2 - {Omga12}**2 - {Omga23}**2' $!ALTERDATA EQUATION = '{s2o2_23} = {s12}*{s13} + {s22}*{s23} + {s23}*{s33} - {Omga12}*{Omga13}' $!ALTERDATA EQUATION = '{s2o2_33} = {s13}**2 + {s23}**2 + {s33}**2 - {Omga13}**2 - {Omga23}**2' $!ALTERDATA EQUATION = '{Q} = 2*{Omga12}**2 + 2*{Omga13}**2 + 2*{Omga23}**2 - {S11}**2 - {S22}**2 - {S33}**2 - 2*{S12}**2 - 2*{S13}**2 - 2*{S23}**2' $!VarSet |NUMVARSFIN| = |NUMVARS| $!DELETEVARS [|NUMVARSINIT|-|NUMVARS|] |
December 19, 2013, 14:22 |
Scott Rumage
Rep Power: 16 |
I have another suggestion that I would like you to try. In Tecplot 360’s top menu line click on “Data” the “Data Set Info..”. A table of variables will appear. From that list there will be a number associated to the x-velocity (and y & z velocity), it may be something like “4: x-velocity, 5: y-velocity, 6: z-velocity”. It is this number that the macro may be seeking for the variable number.
So at the macro prompt, enter the variable number that is next to x-velocity variable name. In this example is would be 4 for U. |
December 20, 2013, 21:17 |
#5 | |
yu. yuxuan
Rep Power: 12 |
January 9, 2014, 19:55 |
Svetlana Tkachenko
Rep Power: 14 |
Thanks for cross-posting.
May 26, 2014, 14:46 |
invalid macro file header
Azadeh Saeedi
Rep Power: 12 |
hello every one,
I just try this macro in tecplot 360, it comes up with this error, I dont know how to fix it, is anybody could help me about it? thanks, |
September 22, 2014, 13:04 |
Rep Power: 12 |
type in the number of the variable,
lookt it up at data->data set info |
September 23, 2014, 11:53 |
Q-criteria and Lambda 2 improvements
#9 |
Hi All,
We will be making the q-criteria and Lambda 2 available later this year in the main interface of Tecplot 360 EX to improve the ease of use. I would recommend that you join our beta program at the link below to be among the 1st to try the new technology. http://www.tecplot.com/my/be-a-beta-tester/ also check the whitepaper on vortex topography here: http://download.tecplot.com/docs/Som..._Revisited.pdf Durrell |
February 12, 2016, 03:27 |
Qcriterion.mcr
#10 |
swetha prakash
Rep Power: 10 |
Thanks a lot for this thread.. Helped me a lot..
macros, tecplot 360 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
