Home > Forums > Visualization & Post-Processing Software > Tecplot
Create variables from instantaneous quantities?
Old   June 10, 2014, 15:46
Default Create variables from instantaneous quantities?
Andras
akiss20 is on a distinguished road
Hi All,
I am diving into the world of unsteady CFD and have some questions about unsteady post-processing in Tecplot. To preface, I am loading a transient 3D CGNS file into Tecplot 360 2011/2012 (depending on the computer) R1 for analysis. I am simulating the stall of a rotor-only calculation of a low speed compressor.
One thing I want to be able to do is to create a variable based on the instantaneous area/mass average at that given time. For example, I would like to define a total-to-static pressure rise coefficient which is defined as
(P_static - massAverage(P_total@inlet))/(0.5*rho*U_tip^2)
I want the mass average of total pressure at the inlet to be a function of time rather than a time average. Is this possible to do in Tecplot? I also want this to be a variable, not just a single value, so I can see how this coefficient is distributed spatially and temporally.
On a more nitty gritty note, I also am struggling with data organization in Tecplot. It seems when I load an unsteady CGNS file it creates a separate zone for each timestep and spatial zone. So say if I have 10 spatial zones (inlet,outlet,blade Omesh etc etc) and 20 time steps, I now have 200 zones. Tecplot will lump them together via time strands in the zone style dialogue box, but if I go to Dataset Info it shows all 200 zones. This would make re-naming the spatial zones, or taking sub-zones very difficult. Is there any way around this?
Thanks!
akiss20 is offline   Reply With Quote
create the file *.foam phongstar OpenFOAM 12 October 14, 2018 18:06
Restarting a run from .trn files What variables do I need?) Badi CFX 2 December 29, 2017 22:13
Possible to create cyliner baffle (internal) using topoSet or stl Mesh? keepfit OpenFOAM 4 February 19, 2017 14:40
[ICEM] how to create a 2d tri mesh with quad mesh in the boundary layer seal2013 ANSYS Meshing & Geometry 3 October 6, 2013 16:09
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
