Home > Forums > Visualization & Post-Processing Software > Tecplot
Script in Tecplot
Old   May 23, 2014, 14:18
Default Script in Tecplot
rds
rds is on a distinguished road
Greetings!
I have a Fluent Transient flow model with 100s of data files. I am trying to see if there is a way in Tecplot to write a script such that:
* each file is loaded;
* the desired contour plot on a pre-defined surface is created;
* the contour plot is saved to a file.
Is this possible in Tecplot?
Thank you in advance for your input!
rds is offline   Reply With Quote
Old   May 29, 2014, 19:10
Default Post-processing 100's of files w/ Tecplot Chorus
Scott Rumage
scott_rumage is on a distinguished road
The easiest way to do this task is to use Tecplot Chorus http://www.tecplot.com/products/tecplot-chorus/ which was created for this type of analysis, plus Chorus provides an environment where you can view and understand these 100s of files in one tool. You can download an evaluation version of Chorus here: http://www.tecplot.com/downloads/free-trial-software/ , and then contact me, and I will help you set up the project, create and view the results. Short videos showing the concept of how we would do this work can be found here: http://www.tecplot.com/products/tecplot-chorus/tecplot-chorus-video-tutorials/ .
BTW ... Tecplot Chorus is a superset of Tecplot 360, so one gets all the functionality of 360 in Chorus.
Regards,
Scott Rumage
s dot rumage at Tecplot dot com
scott_rumage is offline   Reply With Quote
PLOT3D files with Tecplot 2012 nikosb Tecplot 4 April 24, 2018 14:12
Reading Additional Data Quantities from Fluent into Tecplot fremder Tecplot 9 December 16, 2016 15:35
I created a tecplot binary file... Lupocci Tecplot 6 June 27, 2012 19:56
CentFOAM Python Script Installation: Error socon009 OpenFOAM Installation 2 May 26, 2012 09:36
Using Tecplot for contours display david FLUENT 2 August 23, 2005 22:37
