Home > Forums > Visualization & Post-Processing Software > Tecplot
How to generate a cylindrical plane?
Old   October 14, 2014, 01:08
Default How to generate a cylindrical plane?
Sangwoo Kim
swtbkim is on a distinguished road
Hi all.
I'm simulating about fan, and I would like to generate a contour and calculate mass flow rate along radial direction. so cylindrical plane is needed.
In CFD-POST, there is a 'surface of revolution' functionality.
Is there a similar one in Tecplot??
Thank you.
Best regards
swtbkim is offline   Reply With Quote
Old   October 14, 2014, 18:16
Scott Fowler
wsfowler is on a distinguished road
I wrote a Tecplot 360 add-on a while back that would do this. Information on the add-on is here: http://www.tecplottalk.com/addons/radialslice/
Right now you cannot specify an arbitrary orientation, so hopefully your geometry is aligned with one of the primary axes.
It hasn't been compiled for Tecplot 360 EX, but should work with Tecplot 360 2013 and earlier. If you're on Linux, the source code is posted. If you're unable to compile it give our support group a shout and we'll help you out.
Scott Fowler
support@tecplot.com
wsfowler is offline   Reply With Quote
Old   October 15, 2014, 02:01
Sangwoo Kim
This is awesome!
I'll try and give you feedback if i'm lost again.
Thank you very much.
Best regards
Old   October 15, 2014, 04:47
Sangwoo Kim
Hi again!
I didn't understand how to use...
I copied radialslice.dll file, and pasted it into 'bin' folder
and next step is unclear to me.
3. Add this line to your tecplot.add file:
$!LoadAddon "radialslice"
What does it mean??
I found tecplot.add file, but it is not open-able at least in my computer.
Thank you.
Best regards
Old   October 15, 2014, 11:54
Scott Fowler
You should be able to edit tecplot.add with a text editor like Notepad. If you can't, perhaps the permissions on the file are wrong.
If you can't edit this file you can do either of the following:
Add "-loadaddon radialslice.dll" to the command line arguments when launching 360.
or
Drag-and-drop radialslice.dll onto an open instance of 360.
Hope that helps.
Scott
Old   October 18, 2014, 10:53
Sangwoo Kim
I have tried several times, but they failed..
tecplot.add is opened on Wordpad, but it said that it cannot be saved.
I think I should open it with the right of manager, but it was not activated when I right-clicked tecplot.add
I also tried drag-and-drop, but it didn't work.
And what is command line argument?
I'm using Tecplot 360 2012R1, and there is no options like it when launching
Best regards
Old   October 20, 2014, 12:40
Scott Fowler
To use the command-line argument, Tecplot 360 must be in your PATH, or you must 'cd' to the 'bin' directory, where tec360.exe exists. Also, make sure to copy the add-on into the 'bin' directory.
Once you've done that, the command line would look like this:
>tec360.exe -loadaddon radialslice.dll
Old   October 21, 2014, 01:48
Sangwoo Kim
Thank you very much Scott. It's really helpful.
I didn't understand what command line means, and now I do.
I opened it successfully.
I want to make it along z-direction. I decided the radius.
And I think there is no option for the range of z.
I mean, I want to make cylinder along z direction with the height of 0.1m
Is there a way to do?
Best regards
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 18:48
Plane stress and plane strain cases for stress analysis Sargam05 OpenFOAM 0 May 3, 2013 18:16
[blockMesh] How to use blockMesh to generate cylindrical T-junction norkistar OpenFOAM Meshing & Mesh Conversion 2 January 28, 2013 20:53
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
