Home > Forums > Visualization & Post-Processing Software > Tecplot
how to put "sphere" in the ".data" ?
Like Tree1Likes
  • 1 Post By Durrell4
Old   November 18, 2014, 09:49
Default how to put "sphere" in the ".data" ?
wanghuo
hotboy is on a distinguished road
I want to put the sphere witch is draw in "stl" 5.jpg or draw in the solidworks sphere.png in the ".data" to achieve a certain effect like picture 3.3.jpg ?Thank you very much!
hotboy is offline   Reply With Quote
Old   November 18, 2014, 11:53
Default See the other thread for instructions on creating a sphere
Durrell Rittenberg
Durrell4 is on a distinguished road
Send a message via MSN to Durrell4 Send a message via Yahoo to Durrell4 Send a message via Skype™ to Durrell4
I went through the example in the previous thread
Here are the simple steps
1. Create a new layout.
2. Data->Create zone-> Rectangular zone
Set the dimensions to 100, 100, 100
Set XMin, XMax to -1, 1
Set YMin, YMax to -1, 1
Set ZMin, ZMax to -1,1
3. Data-> Alter -> Specify Equations
use this equation: {Sphere} = x*x + y*y + z*z
4. Create an isosurface of Sphere
5. Data-> Extract -> Isosurface
You now have a Sphere in Tecplot.
Let me know how it goes
Durrell4 is offline   Reply With Quote
Old   November 19, 2014, 09:31
Default How to let the sphere and "0.data"in the same layout ?
wanghuo
hello Durrell4!
Thank you very much for your help ,I use you method draw a sphere in a layout .I want let the another database “0.data” and the sphere in the same layout :6.jpg7.jpgBut the result is :8.jpg.Why it is like this?
Old   November 19, 2014, 09:38
wanghuo
hello Durrell4!
Thank you very much for your help ,I use you method draw a sphere in a layout .I want let the another database “0.data” and the sphere in the same layout :Attachment 35312Attachment 35313But the result is :Attachment 35314.The "0.data" is velocity field 9.jpg .Why it is like this?
Old   November 19, 2014, 11:33
Default Loading data with less variables in to a data set with more
Durrell Rittenberg
OK we made progress, but we are not quite there yet. If you have a data set with variables like this
x,y,z,Sphere
and you load the data with variables
x,y,z,u,v,w,Rho,P,T,Cp
Tecplot needs to map the variables that you have to the ones you are loading. If you use data alter to create variables to match in the sphere then it will load correctly otherwise load the sphere second and it will load and append the variables.
It depends what version of Tecplot you are using. Some of the trouble might be the version you are using does not support the variable mapping. What version of Tecplot are you using?
hotboy likes this.
Old   November 20, 2014, 04:35
wanghuo
Thank you Durrell4!The version of Tecplot I am using is "Tecplot 360 2006".Which Version can I use to resolve this problem?
Old   November 26, 2014, 09:57
wanghuo
x,y,z,Sphere
hello durrell!
Thank you very much for your help! I use the tecplot 360 2013R1.Wen I draw the sphere first ,I load the "0.data".the tecplot prompts “1.jpg2.jpg".
If I load the "0.data"first ,and then load the shpere,the tecplot prompts “3.jpg"
I don't know that is why ,Could you help resolve it ?
I write a letter to you .The "0.data" and the sphere is in the letter.
free convection around shallow sphere hamednoordoost@yahoo.com FLUENT 12 April 4, 2013 02:54
Experimental data vs SimpleFoam sphere test case : Cd do not match alsdia OpenFOAM Verification & Validation 1 November 2, 2012 05:37
[ICEM] meshing a sphere - large deviation from perfect sphere murx ANSYS Meshing & Geometry 25 August 15, 2012 12:37
CFX analysis of a sphere - drag too low Rob Findlay CFX 6 March 26, 2007 10:11
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
