Home > Forums > Visualization & Post-Processing Software > Tecplot
cell centered form in TECPLOT
Old   August 21, 2008, 01:16
Default cell centered form in TECPLOT
jack
i want to show variables in the center of mesh,but the result showed by TECPLOT is on node,why? the code is below:
write(33,*) 'TITLE = "3D"'
write(33,*) 'VARIABLES = "X" "Y" "Z" "Rho" "U" "V" "W"'
write(33,*) 'DATAPACKING=BLOCK, ZONETYPE=FEBRICK,N=',numnp,',','E=',nelem,',','VAR LOCATION=([4-7]=CELLCENTERED)'
! WRITE(33,*) 'DT=(DOUBLE DOUBLE DOUBLE DOUBLE DOUBLE DOUBLE DOUBLE)'
!----------------------BLOCK TYPE---------------------------------
DO I=1,NUMNP
WRITE(33,*) CX(1,I)
END DO
DO I=1,NUMNP
WRITE(33,*) CX(2,I)
END DO
DO I=1,NUMNP
WRITE(33,*) CX(3,I)
END DO
DO I=1,NELEM
WRITE(33,*) uh(1,I,0.D0,0.D0,0.D0)
END DO
write(33,'(///)')
DO I=1,NELEM
WRITE(33,*) uh(2,I,0.D0,0.D0,0.D0)/uh(1,I,0.D0,0.D0,0.D0)
END DO
write(33,'(//)')
DO I=1,NELEM
WRITE(33,*) uh(3,I,0.D0,0.D0,0.D0)/uh(1,I,0.D0,0.D0,0.D0)
END DO
write(33,'(//)')
DO I=1,NELEM
WRITE(33,*) uh(4,I,0.D0,0.D0,0.D0)/uh(1,I,0.D0,0.D0,0.D0)
END DO
write(33,'(/)')
do i=1,nelem
write(33,'(<ncount(i)>i10)') nname(i,1),nname(i,3),nname(i,7),nname(i,5),nname( i,2),nname(i,4),nname(i,8),nname(i,6)
end do
close(33)
Old   August 21, 2008, 03:42
Default Re: cell centered form in TECPLOT
saygin
i encountered that problem too. while i had given the variable locations as cellcentered, it interpolated the values to boundary nodes. well, i doesn't matter most of the time but at the boundary for instance it extrapolates from cell centers to cell boundaries, consequently it seems that the result is wrong for example in case of a fixed value boundary condition. using ghost cells and writing the results including the ghost cells will resolve the problem but this is just a specific solution, not a general purpose one.
Old   August 23, 2008, 02:36
hadian
i do not work with finite element option. for structured grid by control volume method: 1-load data to tecplot 2-select the zone(s) 3-"points" tab=>"points to plot"=>select "all cell centers"
Old   August 23, 2008, 02:50
vadim
u should understand that, vertex data is requirement of visualization procedure, in which we need we have some shape function which interpolate color value.
considering this, a cell-centered data is equivalent to picewise-constant interpolation of colors, i.e., we have a fixed color in each cell and so do usually not have a desirable plot.
So you should provide a vertex data (do interpolation of your cell centered data to vertexes) in a consistent manner, if plotter do this for you, it would not be essentially desirable.
btw, Paraview (VTK) (is free) has option for cell-centered data (as i said, picewise constant interpolation),
PS: i use both of paraview and tecplt, paraview is indeed powerful, but bit more difficult to use in particular for begineer
PS: for paraview file format see this: http://www.vtk.org/pdf/file-formats.pdf
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 14:38
gradient calculation of cell centered finite volume method zhengjg Main CFD Forum 10 November 11, 2012 23:13
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Warning 097- AB Siemens 6 November 15, 2004 04:41
