May 15, 2023, 22:40 |
Max value in the extracted line
Hi
I want to know if there is any way to find out the maximum value of a variable on an extracted precise line. I would like to use it to normalize the data on that line with the maximum value. I looked at maximum but it needs two values for comparison. Regards |
May 22, 2023, 17:58 |
Brandon M
Rep Power: 7 |
Hello Ramesh,
You can go to Data>Data Set Info, select your extracted line zone, and use the maximum variable value. Use this value in the Specify Equation dialog to normalize the variables of interest. There are also ways to automate this process using our Python API (PyTecplot). If you have any questions about this workflow, please reach out to support@tecplot.com. |
May 22, 2023, 22:57 |
#3 | |
yes I know this but if I have to use the maximum value or minimum value of a particular variable in the dataset, what is the command that is required to be used is the precise question. currently I am manually copying the maximum value in order to automate it what is the process ? |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
Issues With Exporting From GMSH | rberdon | Mesh Generation & Pre-Processing | 0 | February 11, 2021 11:11 |
Converging Diverging Nozzle with dbnsTurbFoam | Saleh Abuhanieh | OpenFOAM Running, Solving & CFD | 4 | December 13, 2019 10:26 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
